Not winking at you anymore .. it lost interest in you.
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
- Has thanked: 1613 times
- Been thanked: 4078 times
It’s almost stressful driving with no lights on the dash. I’ve been slaying lights in cars all year during Covid on Volvo’s and two flavors of Bavarian wasters
- mdr1220
- Year and Model: 1996 850R
- Has thanked: 44 times
- Been thanked: 7 times
This adventure started with replacing a busted ps pump followed by thinking I had lawnmower syndrome, new starter and PNP switch and it still won't start. Pissed off now and do the one thing that I didn't do when it threw the belt when the ps pump exploded. Check the timing belt.....
Used to have a 01 c70 convertible
- mdr1220
Hopefully it will start once I put a new belt on and it didn't skip the timing. Any tips to make this as painless as possible? First time doing a Volvo 5 cylinder.
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
There are some great tutorials found here that I found helpful when I did my s70 for the first time. It was my first timing belt every and those tutorials plus videos got me through the job.mdr1220 wrote: 10 Jun 2021, 05:47 Hopefully it will start once I put a new belt on and it didn't skip the timing. Any tips to make this as painless as possible? First time doing a Volvo 5 cylinder.
viewtopic.php?f=1&t=47793
Your car is different than mine in that you have the hydraulic tensioner and different power steering pump that would have made your job different.
Many guides report that you can get the timing belt off WITHOUT removing the crank pulley. That was not the case with my car as the fuel line is routed different than on your car. On my car it routs along frame near crank pulley and takes up space that would be required to remove belt.
However, if you do remove the crank pulley, you will have so much more room. You will need something significant to get the crank bolt out though.
- mdr1220
Thanks amblerman. This forum has been a timesaver for me.amblerman wrote: 10 Jun 2021, 07:57There are some great tutorials found here that I found helpful when I did my s70 for the first time. It was my first timing belt every and those tutorials plus videos got me through the job.mdr1220 wrote: 10 Jun 2021, 05:47 Hopefully it will start once I put a new belt on and it didn't skip the timing. Any tips to make this as painless as possible? First time doing a Volvo 5 cylinder.
- Has thanked: 317 times
- Been thanked: 531 times
I've never needed to remove the crank pulley to install the timing belt, but it does make it easier. Check that everything lines up first, you might have gotten lucky. A leakdown test will confirm or eliminate valve damage before doing the work.
- mdr1220
Thank you. I'm going to do the leakdown test after i replace the beltbmdubya1198 wrote: 10 Jun 2021, 10:27 I've never needed to remove the crank pulley to install the timing belt, but it does make it easier. Check that everything lines up first, you might have gotten lucky. A leakdown test will confirm or eliminate valve damage before doing the work.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
It's been too many years since I did the belt on my first 850, but one thing that helps give you a bit more room - on the 70 series too - is to jack up the motor, pull both bolts out of the motor mount, and if you have to, put a bolt back through the top hole into the bottom hole in the motor. If you have enough paraphernalia, and can just block off the motor with cribbing, take the mount off completely.mdr1220 wrote: 10 Jun 2021, 17:36Thank you. I'm going to do the leakdown test after i replace the beltbmdubya1198 wrote: 10 Jun 2021, 10:27 I've never needed to remove the crank pulley to install the timing belt, but it does make it easier. Check that everything lines up first, you might have gotten lucky. A leakdown test will confirm or eliminate valve damage before doing the work.
I couldn't find the crank gear mark on the Rescue R until I had it in my hands. The car was apart for a week, but some of that time was me having a man-to-man chat with various body parts, convincing them to lay down on the concrete again.
- foggydogg
Holy mustache, I just stumbled onto this earlier post. Natty Boh Tall Boy ! You are a true Boy from Bal'mer !
That takes some of the pain out of the wrenching.
