Howdy Volvo experts!
When I started the car today, it wasn't as smooth as usual. Felt it was choking. Then had this continuous revving up and down. It continued for a while then went away (sometimes it doesn't go away and continues actually). I tried to start the car again multiple times and got the same behavior.
Anyone had a similar behavior? Any thoughts what could be the problem?
Here's the video I recorded:
Help with erratic revving up and down
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
Only had it once when the weather was very hot, drove 45 minutes and it was idling that when I arrived, 3 hrs later after cooling down it was normal again.
Only happened the one time.
You might want to check for codes.
- RickHaleParker
- Been thanked: 958 times
Ambient Temperature related ... Ambient Temperature sensor?
Try cleaning the MAF sensor which does double duty as the Intake Air Temperature sensor.
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
Sounds like what happens when the IAC is on the fritz. Do P2's have one?
5 others that came and went
- Been thanked: 466 times
You have 173K miles on the odometer.
You should clean the throttle body.
I wrote a DIY in forum, basically you can slide the TB out to the driver side for cleaning.
No need to remove the Intake manifold to remove the TB.
- hajjat
- Year and Model: 04 Volvo XC70
Cool. Found your DIY post viewtopic.php?f=10&t=78629. I'll give it a shot and see if that solves the issue. Never done it before, hope it goes smoothly (n00b here)!You should clean the throttle body. I wrote a DIY in forum, basically you can slide the TB out to the driver side for cleaning
No, no codes.Sounds like what happens when the IAC is on the fritz. Do P2's have one?
Never done that before either. Let me buy a cleaner and try it out.Try cleaning the MAF sensor which does double duty as the Intake Air Temperature sensor.
Thanks everyone for the great insights, I'll try these out and let you know how it goes!
- RickHaleParker
Not a cleaner. MAF cleaner and nothing other them MAF cleaner.
- Has thanked: 1497 times
- Been thanked: 3809 times
On a turbo , that’s probably loose induction somewhere. Start at the air cleaner, and work your way through each clamp and hose looking for loose stuff. Then go back and remove each piece looking for holes
This will take about 2 hours, total.
