Hot exhaust fumies
radek93
Year and Model: S70 98
Has thanked: 2 times
Been thanked: 3 times
Hot exhaust fumies
Post by radek93 »
Volvo S70 B5254T
Is it normal to have very hot exhaust fumes? After 15 km of driving, my exhaust fumes are so hot that my hand burns at the end of the exhaust. Is it normal? Maybe a clogged catalyst? Large amounts of exhaust gas do not fly. Long-term correction is fine, around 0.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Yeah, it's a car. Literally fire and explosions inside the engine. It doesn't normally take a lot of driving to get all that stuff up to temperature. Unless you're having problems running or codes showing up, I would say you're fine. Putting a hand behind your exhaust and feeling the temperature is not exactly a very accurate or scientific way to determine if there's some issue.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1002 times
Post by volvolugnut »
To get all nerdy/technical, because the engine is only about 25 percent efficient as best, 75 percent or more of the fuel energy goes out the exhaust or radiator. A turbo uses some of this energy, but not much.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Hot exhaust gases would be a sign the cat is working as it should.
BMW 540i 2002
S70 Base 2000
befarrer
Year and Model: 1998 V70 AWD
Been thanked: 24 times
Post by befarrer »
Should see these new Diesels, when doing an exhaust filter regeneration, exhaust temperature is about 1100f.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
radek93
Post by radek93 »
One more question. When I reach the lights and I have the clutch pressed, the engine speed is higher than idle. When stopped, they set themselves idle. The car can even roll gently and the engine RPM is higher anyway. I changed and cleaned the idle valve.
radek93
Post by radek93 »
FlyingVolvo wrote: 08 Jun 2021, 17:27 Yeah, it's a car. Literally fire and explosions inside the engine. It doesn't normally take a lot of driving to get all that stuff up to temperature. Unless you're having problems running or codes showing up, I would say you're fine. Putting a hand behind your exhaust and feeling the temperature is not exactly a very accurate or scientific way to determine if there's some issue.
The use of my hand to check the temperature may not be reliable, but in the V70 II 2000 after driving about 30 km, including a dozen or so kilometers on the highway, I can hold my hand behind the exhaust and it does not burn a lot. In addition, it seems to me that more exhaust fumes are coming out. In my car, after a few kilometers, I will not keep my hand behind the exhaust for too long because it burns a lot
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
radek93 wrote: 06 Jul 2021, 00:19
Try getting an infrared/laser thermometer and actually measure it. Odds are it's <= 350 F at the tail which should be fine.
radek93
Post by radek93 »
I used a thermocouple multimeter to measure it. The temperature is 180 ° C (356 ° F). V70 II will be measured today.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
You can't compare two practically different cars.
V70 p2 have different engine management,catalytic converters,sensors....and much more.
Plus....when engine runs on LPG....it runs a bit hotter than engine on petrol.
That said....temperature in combustion chamber is higher when engine runs on LPG.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
