96 850 turbo- no start...no spark...no cel
mrbrightside2009
- Year and Model: 96 850 turbo
Re: 96 850 turbo- no start...no spark...no cel
also found this disconnected... between ecu box and coolant tank....my mechanic friend has somebody working for him and he had him swap the engine (big mistake) but apparently missed all these connections and doesn't know what the hell he is doing.
- Has thanked: 1511 times
- Been thanked: 3829 times
That’s just t he coolant level sensor, not material here.
Until you see the CEL light on in key position II, or otherwise verify your ECU is powered up, you will go around in circles, figuratively.
mrbrightside2009
- Sveedy
- Has thanked: 418 times
- Been thanked: 457 times
It's just an open port. Maybe to let the air back out that comes into the box via the snorkel tube.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 294 times
- Been thanked: 767 times
Agreed that is a blank connector port. It's not a vent though, it is smooth on the inside. No wires, no holes, just a port.
The snorkel tube on the ECU box is actually an exhaust, not an intake. Air is drawn from the cabin through that fat round tube from the firewall, passes over the ECU, exhausts out the snorkel.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- misha
- Has thanked: 152 times
- Been thanked: 403 times
Check the main fuel injection relay on cooling fan carrier if it's getting power.
It's grey one.
https://www.google.com/search?q=volvo+8 ... CnaT6SucFM
It's grey one.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Where are you located in PA? Maybe we have someone nearby who can apply the magic touch amd find the loose connector.
- 2514 Views
Last post by Roger_850T
- 2883 Views
Last post by ndphotonl
