bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I actually did it myself on the S70 without taking any measurements... believe it or not, it's damn near perfect. Well, maybe I took one or two measurements on the front to rear of the tires just to get that slight toe-in.
Hopefully I can get over there this afternoon, these things always come up when my schedule is jam packed. Then I need to see if I can cut the FWD exhaust and make it work temporarily... I can't handle the drone!
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
Did an oil change and a drain and fill on the coolant. Happy Canuck Day to All!
2008 S60 2.5T Auto (Sold)
Been thanked: 4068 times
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Did you fix it using a bolt extractor??
mdr1220 wrote: 27 Jun 2021, 13:10 IMG_20210627_150122308_HDR.jpgI'm f***ed. One of the exhaust cam bolts snapped as I was rotating the cam to line back up with the marks.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
mdr1220
Year and Model: 1996 850R
Has thanked: 44 times
Been thanked: 7 times
Post by mdr1220 »
cuhfs wrote: 01 Jul 2021, 18:45 Did you fix it using a bolt extractor??
Haven't touched it since I broke it. Work and weather got in the way, starting on it tomorrow but I picked up a set of left hand drill bits and hopefully I have stub of the bolt showing when I pull the cam gear tomorrow.
Used to have a 01 c70 convertible
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I topped 600 miles on a single tank of 91 octane fuel on a round trip to Cape Cod, at an average of 33.5mpg, in the 2000 m/t base V70 without functioning a/c.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
brunocerous wrote: 02 Jul 2021, 08:24 I topped 600 miles on a single tank of 91 octane fuel on a round trip to Cape Cod, at an average of 33.5mpg, in the 2000 m/t base V70 without functioning a/c.
Wow! That's some excellent gas mileage! It's really crazy to see just how high you can get that number on these cars when you drive them right. My cousin once got around 31 mpg in his old '99 NA auto S70.
brunocerous
Right? I was impressed when I approached 400 miles on a single tank. Oh, and I did it with a brand-new clutch. The old one, had some of the spring elements (?) bent around the 7 o’clock position.
2000 V70 OE clutch at 188,000 miles
yanga001
Post by yanga001 »
Replaced the gear shift light with an led off a amazon light strip and some resistors. Was a ***** to get into the slot but I like the results.
bmdubya1198
Got my alignment fixed today thanks to my cousin. I wish I had just had him do it the first time... they tried to tell me at the place I went the other day that the P2 specs would be perfectly fine for my car (and that their computer only went back to 2001 (hence P2 specs) which I also don't totally believe since it's the same Hunter software most shops have), which I knew for 100% fact was wrong. He also claimed that because it's lowered, my steering wheel was WAY off to the right. Not the case! It was practically undrivable.
Took 10 minutes to correct it to P80 specs, and now the wheel is perfectly straight... imagine that!
