2006 XC70 headlight polishing/removal?
Has thanked: 1846 times
Been thanked: 1710 times
I have to clean/polish our 06 XC70 headlights as they are badly oxidized at the top. To clean the top I think I will have to remove the headlights to get better access and to make sure I don't scuff the paint above the headlight.
Been a while, but unlike the P80, where you can remove the headlight without removing panels/bumper, do you have to remove the front bumper to remove the headlights?
Thanks,
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
scot850 wrote: 02 Aug 2021, 19:46 do you have to remove the front bumper to remove the headlights?
On the MK2 70s the bumper cover needs to come off.
Thanks Rick. I seem to recall reading that somewhere but could not find any links in the database for that. What a PITA that is. So much for advancing technology and making stuff easier to work with. :cry:
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
I'm with you on this one. I can't get it either. I mean glass is basically sand and it seems to me there's plenty of it. Plastic headlights. Do the car/truck manufacturers really save that much money? I'm just wondering if you can use glass lenses from a 2004 xc70 and convert them over...2001-2009 S60's apparently is the same light fixture .. maybe it's possible to swap out plastic for glass..
RickHaleParker
MDK wrote: 03 Aug 2021, 03:29 Do the car/truck manufacturers really save that much money?
Weight ... Fuel economy. Not much but a lot of 0.1s add up.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I've cleaned up a few lenses and in my opinion its easier/faster not to remove the headlight. On a bench it tends to move around and you need to clamp it fown somehow. Nah, just mask with tape and go for it!
BMW 540i 2002
S70 Base 2000
MRScott
Year and Model: 04.5,05,06,2011
Post by MRScott »
Also a rock that would crack a glass lens won't on a plastic one.
RickHaleParker
On plastic lens I:
  • 1. Wet sand them with 1500 - 3000.
    2. Buff them with a Compound until clear.
    3. Clean off everything
    4. Spray them with a UV-Resistant Clear Coat.
Off the car so you do not mess up the paint.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
RickHaleParker wrote: 05 Aug 2021, 17:02 On plastic lens I:
This is the way I have done this, except I have not removed from the car.
RickHaleParker
MRScott wrote: 05 Aug 2021, 13:27 Also a rock that would crack a glass lens won't on a plastic one.
Glass stays clear much longer. You can fill chips the same way you repair cracks in a Windshield. You can buff out light pitting on glass with paste made from Cerium Oxide and H₂0.
