Well.......that was stupid! Help! Topic is solved
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 264 times
Just ordering some parts for my XC to include Timing belt kit and PCV kit etc. Went to clean off the engine serial number sticker so I could read it and used Brakleen to clean off the grease. The solvent took off the numbers and now I cannot read it! Can I find this number anywhere else? Thanks.
2003 XC 70 (sold)
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
- Has thanked: 928 times
- Been thanked: 1002 times
That reminds me of the time I tried to carry a little gasoline in a styrfoam cup.
- Has thanked: 1507 times
- Been thanked: 3824 times
i dont think there is a chassis break on the 2003 timing belt but if you post up your last 6 of your VIN that might help ID the right parts too.Blacklab467 wrote: ↑13 Aug 2021, 09:13 Just ordering some parts for my XC to include Timing belt kit and PCV kit etc. Went to clean off the engine serial number sticker so I could read it and used Brakleen to clean off the grease. The solvent took off the numbers and now I cannot read it! Can I find this number anywhere else? Thanks.
- RickHaleParker
- Been thanked: 958 times
Timing componets breaks are based on engine serial number not chassis number.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
On the back of the block, can't be seen directly because its under a bodywork lip.Blacklab467 wrote: ↑13 Aug 2021, 09:13 Just ordering some parts for my XC to include Timing belt kit and PCV kit etc. Went to clean off the engine serial number sticker so I could read it and used Brakleen to clean off the grease. The solvent took off the numbers and now I cannot read it! Can I find this number anywhere else? Thanks.
After you find the location clean it with carb or brake spray and a toothbrush then put your smartphone in there and take a few pics.
- Blacklab467
Got it! Thanks everyone.
2003 XC 70 (sold)
