Injector leaking into cylinder it sounds like? Would explain the clean cylinder relative to the others.
Compression test and spark plug questions Topic is solved
- Has thanked: 2212 times
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I have to remove the fuel rail to do the PCV cleaning. Could I find any clues to a leak while doing that? Maybe replace the injector o-rings and manifold seals?
FireFox31
You might see a telltale in the intake manifold once it has been removed. Replacing the 'o' rings and seals won't fix the problem. It is the internal injectors seal that is dirty possibly. Having the injectors cleaned and tested would be a possibility while they are out for the PCV service.
- Has thanked: 1611 times
- Been thanked: 4075 times
Nice high compression for 200k miles. Good ring and valve sealing. A lot of reasons the numbers can fluctuate during the pump up, I would not worry about that.
It’s about &20-25 each to get injectors cleaned and “ balanced” but these things seem to last a long time on Volvos
- Has thanked: 312 times
- Been thanked: 818 times
Yes. Put the rail-with-injectors on a towel on top the valve cover and turn the key to position II to activate the fuel pump and put some pressure in the system. None of the injectors should leak fuel.FireFox31 wrote: 16 Aug 2021, 17:11 I have to remove the fuel rail to do the PCV cleaning. Could I find any clues to a leak while doing that? ...
- FireFox31
That sounds fair. Looks like I have to mail them away to be cleaned. Can anyone recommend one cleaning company over another?abscate wrote: 17 Aug 2021, 01:33 It’s about $20-25 each to get injectors cleaned and “balanced” but these things seem to last a long time on Volvos
Great, I can easily try that during the PCV cleaning! Thanks for the tip.erikv11 wrote: 17 Aug 2021, 07:56 Yes. Put the rail-with-injectors on a towel on top the valve cover and turn the key to position II to activate the fuel pump and put some pressure in the system. None of the injectors should leak fuel.
Did you say that the knock during each crank was the injector? The fuel pump relay was removed for the compression test. Two other cylinders gave a knock on one of their 5-6 cranks, but cylinder 5 knocked each time.
FireFox31
I have used https://www.cruzinperformance.com/ with good results and I know others on here have used https://www.mrinjector.us/.
Just up the street from me in Glenville. nY.
I like these guys since they brought me food when I was in Antarctica
https://injectorrepair.com/injector-service/
- 3132 Views
Last post by Roger_850T
- 26 Replies
- 2323 Views
Last post by patcal
- 3944 Views
- 1973 Views
- 1780 Views
Last post by Livens
