bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Yeah, that’s a pretty extreme failure. I’ve never seen that on any of these cars.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Sveedy wrote: 19 Aug 2021, 09:31 I just can't get over that amount of rust. Exactly how many years did that thing spend on the bottom of the ocean?
My rear calipers look like this (with pin holes intact) and I swear they function fine. I'm about to rebuild them with new boots. Would love to clean them up and protect them from further rust.
FireFox31
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
foggydogg wrote: 19 Aug 2021, 14:34 Hope springs eternal, ...
But it doesn't look any better out here than it did under the car.
I think Plan B just became Plan Only.
Where did that used to be?? Is that a front cross member?
bmdubya1198
BlackBart wrote: 20 Aug 2021, 14:26 Where did that used to be?? Is that a front cross member?
Yup, and it looks like it took a hell of a beating!
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Rear portion of the cradle, under the steering rack. Came to me wiith the whump pre-installed.
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
My xc90 passenger light was intermittently going our. The wife got pulled over for it yesterday so I decided to look into. I thought it was going to be a bad bulb or a loose connector. This time it was a melt down. I assume I'm going to have to replace the whole assembly since this connector is pretty well wired in.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
ZionXIX wrote: 20 Aug 2021, 20:09 My xc90 passenger light was intermittently going our. The wife got pulled over for it yesterday so I decided to look into. I thought it was going to be a bad bulb or a loose connector. This time it was a melt down. I assume I'm going to have to replace the whole assembly since this connector is pretty well wired in.
looks to be a loose connection at either the ground to wire, or lights ground to the connector ground. corrosion or air gaps can allow for arcing or increase the resistance which leads to overheating. Given the melt pattern i almost am more inclined to say a loose seated connection. I use a good amount of dielectric grease to get around this issue as my chinesium HID light bulbs have very loose fitting connectors. Nothing a little bit of grease, electrical tape, and zip ties cannot fix.
EDIT: Given the intermittent nature, i am more inclined to point to a loose seated connection. If its an HID bulb then that high voltage is much more inclined to jump the gap and keep firing. This can result in overheating via slight arcing.
2008 S60 2.5T Auto (Sold)
ZionXIX
Post by ZionXIX »
yanga001 wrote: 20 Aug 2021, 20:26
No HID here. Just basic bulbs hardwired so no ballast to deal with. I applied ample electrical tape and am considering a zip tie. For now it's working and I may make a run to the junkyard to get a good used one.
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
This topic - section, is an encyclopedia ! i think each newbie would be able to repair his car just reading this whole topic...
Manov
ZionXIX
Post by ZionXIX »
I decided against buying a used headlight for my melted bulb connector. Amazon sells H11 pigtail connectors with ceramic coating. $8 for a pair. Now I have a working low beam light and like 6 inch of extra wiring when I need to change the bulb again in the future. I used some nifty heat shrink connectors with solder built in.
