bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
SesMoge wrote: 26 Aug 2021, 00:29 Replaced two vacuum hoses this time, but throttle response is still weak. Will die if clutch is released too quick. 🤔
Attempted to change the pollen filter. Ehm, no. 😅 Looks like this car has been breathing dirty air all it's life. No wonder the AC doesn't blow cold.
The battery also lost all it's charge yesterday. After running and moving a little, I was unable to start the car again. Bad alternator? Bad battery connections, terminals, etc. ? More and more problems show themselves. 😎
I would check for any draw on the battery. The glove box light is a common one.
You can add the cabin air filter if you want, you just need the frame for it that goes over that intake to the blower motor.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
IPD has a filter kit for that.
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
I highly encourage the filter kit. My 850 never had one and the amount of disgusting crud I had to scrape off of the evaporator will give you nightmares. Pics available by request.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
ZionXIX wrote: 26 Aug 2021, 14:49 I highly encourage the filter kit. My 850 never had one and the amount of disgusting crud I had to scrape off of the evaporator will give you nightmares. Pics available by request.
Thanks for not publicly posting disgusting dirty pictures on MVS. :wink:
Has thanked: 1843 times
Been thanked: 1710 times
You can pull the frame from a V/S70 and fit it to a 850.
RickHaleParker
scot850 wrote: 26 Aug 2021, 21:23 You can pull the frame from a V/S70 and fit it to a 850.
A P80 V/S70 1996–2000, P80 C70 1996 - 2005.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Oh i have been too looking for filter thingy.. happened the same. Bought new filter and.. no frame.
Has thanked: 1502 times
Been thanked: 3817 times
abscate wrote: 04 Oct 2018, 15:07 528133DD-68BA-4E07-B342-B9C28628335B.jpeg5EFCA6A9-2780-4031-91B9-E5345C55B713.jpegWaited in vain for the Rs to show up for the ferry. Even kept the second place row open for them. Alas, they are still en route so I boarded.
June caught the ferry an hour before.
Well, this was going on three years ago on a business trip - suddenly this looks like it might be my new location until retirement.
Circle of Life...
Well are you planning to move closer to SWMBO for sure? Sorry, didn't quite get the cryptic note above.
BlackBart
Post by BlackBart »
xanthefin wrote: 29 Aug 2021, 10:10 Oh i have been too looking for filter thingy.. happened the same. Bought new filter and.. no frame.
https://www.ipdusa.com/products/16396/C ... 525-125943
https://www.ipdusa.com/products/4983/Ca ... 525-109371
