I would check for any draw on the battery. The glove box light is a common one.SesMoge wrote: ↑26 Aug 2021, 00:29 Replaced two vacuum hoses this time, but throttle response is still weak. Will die if clutch is released too quick.
Attempted to change the pollen filter. Ehm, no.Looks like this car has been breathing dirty air all it's life. No wonder the AC doesn't blow cold.
The battery also lost all it's charge yesterday. After running and moving a little, I was unable to start the car again. Bad alternator? Bad battery connections, terminals, etc. ? More and more problems show themselves.![]()
You can add the cabin air filter if you want, you just need the frame for it that goes over that intake to the blower motor.
