Removed the accessory belt tensioner.
Gives a much better view.
And marked the cam gears and top of the timing belt
1998 V70 GLT FWD timing belt change...starting now!
Sufbug
- Year and Model: 1998 V70
- Has thanked: 2 times
- Been thanked: 2 times
Re: 1998 V70 GLT FWD timing belt change...starting now!
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
Sufbug
Removed the accessory belt tensioner ...much easier view...
And marked the top of the timing gears and timing belt
Almost ready to cut belt off....
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
Yeah, there you go. And marking the timing belt and gears is the right thing to do. I'm not sure if the valve springs will force the cam out of alignment, though. As I said, I did this job with the lock tool, but you might want to find some way to keep the cams from rotating.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
Sufbug
Nevada1906 wrote: ↑10 Oct 2021, 08:10
I will do my best. I have to replace one of the cam seals....so I have to remove some parts, dunno if the cam lock foam thingy will work.
I did mark the belt and count the teeth on the belt (crazy but what the heck) and marked everything up.
16 bumps between cams
43 bumps to my imaginary marking (straight edge balanced on other parts of engine bay, don't ask...lol)
Will transfer marks to the new belt as a reference point, multiple reference points.
Thanks Nevada --- thanks for keeping an eye on me over here
Sufbug
Ok the water pump and the tensioner, and the pulley are off
Had to pull the exhaust cam gear off. Replacing the seal....
CN90---- thanks for the writeup on removing these dang seals! It took me 90 mins , and what a PITA.
Now, one small problem ....the cam gear isn't keyed, and the bolt holes to put the gear back on are eccentric.
I am gonna do the final tighten it when I have the belt on.... So hopefully the belt will position that exhaust gear in place. I have the intake cam gear locked down with a sturdy foam block.
So, now we are gonna put things back together. After I get the exhaust camshaft gasket in place.
Ok here are some lovely pics!
Thoughts or suggestions? Or damn the torpedoes, and full engine power.......
- misha
- Has thanked: 152 times
- Been thanked: 402 times
That would be a timing belt shield.
In case of serpentine belt failure it should keep the timing belt safe and protect it from wrapping a serpentine belt around crankshaft pulley.
You didn't need to remove ecu(s) and their box...btw.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sufbug
Ok cool. I will keep that bolt in there. To protect the timing belt and serpentine belt like you said Misha.
Yeah, taking out the ecu just to get breathing room. Lol
The water pump is back in.
Sufbug
Help, I'm stuck fellas!
Trying to get the belt behind the crank pulley.
Is there some secret?
I did take out the four 10mm bolts. But not the center bolt.
Does the center 36 mm have to come out?
- Has thanked: 927 times
- Been thanked: 1000 times
You do not need to remove the crank pulley. Start the belt over the crack pulley first and work upwards.
- 998 Views
Last post by beigg
- 2522 Views
Last post by SuperHerman
