What is this part that I broke? Topic is solved
- famfeld
- Year and Model: 04 xc70
- Has thanked: 9 times
- Been thanked: 6 times
In front of the airbox on my 04 Volvo xc70. It is like a valve for some kind of air recirc pump. Not exactly sure, but it broke apart as you can see in the pic
- Been thanked: 471 times
- Volvo PN 31400692, about $60-$70.
Use only Volvo part. Avoid the aftermarket junks.
- See this thread:
https://volvoforums.com/forum/volvo-s60 ... lve-84577/
- See this thread:
How many miles on your 2004 XC70?
Most consider:
1. Replacing this part for sure.
2. Lubricate the vacuum pump itself. I wrote it up somewhere in forum.
I will look for it later...
Most consider:
- Has thanked: 1505 times
- Been thanked: 3817 times
Brake vacuum sensor. You can glue it back together with a zip tie around it, too. The new part is improved and doesn’t break ( brake?) like the OE.
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 42 times
JB plastic weld works great
Make sure your vacuum pump isn’t on full time after that repair. That will burn it out and it isn’t cheap.
