Key is 64 Bytes at addresses 00ffff00 - 00ffff30.
CA = CAN Address
OC = OpCode(s)
What are the OpCode(s) ?
Format CA OC <64bit Key> ?
Manual Decrypt Eeptom need xor s flash+xor s 01 02 03 04 05 06 07 and so every seven bytes xor s 01...07RickHaleParker wrote: ↑10 Oct 2021, 15:58Key is 64 Bytes at addresses 00ffff00 - 00ffff30.
CA = CAN Address
OC = OpCode(s)
I cannot make heads or tails out of this.
RickHaleParker wrote: ↑11 Oct 2021, 23:40I cannot make heads or tails out of this.
Lets start with what does the variable s represent?
My best guess is s is Byte 00 of the 8 byte string.
( For x = 01 -07, Bx = B0 xor Bx ) for the first half of a 16 byte address.
( For x = 09 - 0f, Bx = B8 xor Bx ) for the second half of a 16 byte address.
Code: Select all
03 95 7F D4 C9 7C 5E | BA CB 99 E0 E9 60 B4 | 3D 09 ---FLASH KEY FIRST 16 BYTES
FF FF FF FF FF FF FF | FF FF FF FF FF FF FF | FF FF ---ENCRYPTED EEPROM FIRST 16 BYTES
0 1 2
FLASH XOR EEPROM
FC 6A 80 2B 36 83 A1 | 44 35 67 1E 17 9E 4A | C0 F4 ---FIRST 16 BYTES OF DECRYPTED EEPROM
Flash ( 7 Bytes ) xor Eeprom ( 7 bytes, each byte reduced by set number ) = Decrypted ( 7 Bytes )mikeak2001 wrote: ↑12 Oct 2021, 16:33
From what I can work out it is as follows:
First 7 bytes of the key are xor'd with the first 7 bytes of the eeprom.
Second 7 bytes of the key are xor'd with the second 7 bytes of the eeprom however the crytped byte needs reducing by 1 bit before xor.
for e.g BA^FF = 45
However BA^(FF-01) = 44
For the third set of 7 bytes subtract 2 dec or 02 hex.
e.g 3D^(FF-02) = C0
Seems to work as far as i've gone in the last 20 mins.
Haven't gone further than this yet though. Will continue when I have some more spare time.
Notes: There are only 256 bytes of keys in the flash file but there are 2048 bytes in the Eeprom file. Recycle the keys?
Code: Select all
FC665B C99B MOV.W:G R3,R0
FC665D CFA801 JSR.W FC6806H
FC6660 F860 MOV.B:Q #0H,R1H
FC6662 C99B MOV.W:G R3,R0
FC6664 F920 MOV.W:Q #0H,R2
FC6666 B0133D00 DIVU.W #003DH
FC666A C18B MOV.W:G R2,A0
FC666C B08B00FFFF MOV.B:G FFFF00H[A0],A0
FC6671 89E9 XOR.W A0,R1
FC6673 C99B MOV.W:G R3,R0
FC6675 F920 MOV.W:Q #0H,R2
FC6677 B0130700 DIVU.W #0007H
FC667B C8E9 XOR.B R0L,R1L
FC667D 02 MOV.B:Z #0,R0L
FC667E BB0F JMP.B FC668EH
FC6680 D6B0E90300 BCLR 0,0003E9H
FC6685 D6BDE90300 BSET 5,0003E9H
FC668A E8C0 SHL.B #1H,R1L
FC668C E8B1 ADD.B:Q #1H,R0L
FC668E 4608 CMP.B:S #08H,R0L
FC6690 CA11 JGEU FC66A2H
FC6692 D6B5E90300 BCLR 5,0003E9H
FC6697 D8C7 BTST:G 7,R1L
FC6699 DAE6 JEQ FC6680H
FC669B D6B8E90300 BSET 0,0003E9H
FC66A0 BBE4 JMP.B FC6685H
Code: Select all
void eeprom_decrypt(unsigned char *eeprom, int len, unsigned char *crypto, unsigned char *decrypted)
for (int i = 0; i < len; i++)
decrypted[i] = eeprom[i] ^ crypto[i % 0x3d] ^ (i / 7);
We need to figure out if you are getting read errors, have a bug in your decypher source code or something else like we don't have it figured out completely. How about posting the source code for your decypher.
