The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
- Has thanked: 1505 times
- Been thanked: 3818 times
Re: The Resurrection of (10/1998 to 01/2021) Elizabeth 1999 V70T5M56 Cylinder Head Job
I might have an answer. The first bearing in e ch cam has two thrust surfaces which control axial play. If those surfaces are gnarly the cam will lock.
- Has thanked: 927 times
- Been thanked: 1000 times
May the Patience and Fortitude Lions be with you.
I have let some gasket sealer get loose onto the thrust surface. Heavy sticky stuff. It might be that is gluing up the cams rotation.
Can’t get it to it this week but will clean it shiny clean and try that
Permatex aviation goop. Uncured
Cleaned with wood scrapers, acetone
HeAvily greased thrust surface of intake cam , all faces
Installed intake cam and brought cover down with tool and it turns with normal valve resistance.
I think it was just an assembly error.
Tomorrow , it’s both cams plus glue down
- Has thanked: 304 times
- Been thanked: 517 times
May the Volvo gods be with you!
brewmaxwell649
- Year and Model: 2001
She needs more than a part to be replaced : time, sweat, more than tools. Couldn't you keep it aside 'till spring time ? During this time lapse, may be willyou have a britght idea about how to do. Mobdro
She is a great winter car so I want her for winter. She also tows as well as is a better Husky Hauler than my RaceBeetle…..
..and it’s 40F cool and dry outside…perfect wrenching weather
Permatex 518 and cam cover installed.
Both cams turning well
