The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
Has thanked: 1507 times
Been thanked: 3824 times
Re: The Resurrection of (10/1998 to 01/2021) Elizabeth 1999 V70T5M56 Cylinder Head Job
I might have an answer. The first bearing in e ch cam has two thrust surfaces which control axial play. If those surfaces are gnarly the cam will lock.
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
May the Patience and Fortitude Lions be with you.
abscate wrote: 13 Oct 2021, 13:36 I might have an answer. The first bearing in e ch cam has two thrust surfaces which control axial play. If those surfaces are gnarly the cam will lock.
I have let some gasket sealer get loose onto the thrust surface. Heavy sticky stuff. It might be that is gluing up the cams rotation.
Can’t get it to it this week but will clean it shiny clean and try that
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Ah, so not gouging or scoring, but maybe hardened goop...?
Permatex aviation goop. Uncured
Cleaned with wood scrapers, acetone
HeAvily greased thrust surface of intake cam , all faces
Installed intake cam and brought cover down with tool and it turns with normal valve resistance.
I think it was just an assembly error.
Tomorrow , it’s both cams plus glue down
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
May the Volvo gods be with you!
brewmaxwell649
Post by brewmaxwell649 »
She needs more than a part to be replaced : time, sweat, more than tools. Couldn't you keep it aside 'till spring time ? During this time lapse, may be willyou have a britght idea about how to do. Mobdro
She is a great winter car so I want her for winter. She also tows as well as is a better Husky Hauler than my RaceBeetle…..
..and it’s 40F cool and dry outside…perfect wrenching weather
:lol:
Permatex 518 and cam cover installed.
Both cams turning well
