Cranking Opinion
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Cranking Opinion
Post by Mr. Detail »
Hate to ask this after just spending over $700 to install a new alternator and belt and another $150 for a battery but lately when I turn the key, there are times when it seemingly takes several cranks, (like 7 times) before it turns over.
Is this a sign of a failing starter motor?
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
Are you saying the starter cranks the engine over 7 times before it fires up? Or do you have to turn the key 7 times before the starter will even crank?
Mr. Detail
Hey Crism;
The former, "the starter cranks the engine over 7 times before it fires up".
maybe something else huh?
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 483 times
Post by jonesg »
usual suspect is loss of fuel pressure at the rail.
chrism
Post by chrism »
Try turning the key on and off to Position I ignition only three or four times just before cranking the starter and see if the extra pump priming get it to fire quicker. If so then maybe others can advise on any check valve stuff.
Mr. Detail
Ok, will do.
