1994 850 no start, no crank
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Sluggish then nothing. When I removed the starter there was oil on top of the Bendix part of the starter. I took my old starter to auto zone and they said it was good. So I put that back in bc the cheep starter the wire had broken from the solinoid.. I'm getting now nothing just a click. Fuel pump is running all lights and fan work. What's going on? At a loss
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
hi have you tested battery?if thats good id next change the starter relay as there cheap and do not last forever,my 855 was same and it was relay,bugger to get too the thing,good luckloveMy850 wrote: ↑31 Oct 2021, 19:45 Sluggish then nothing. When I removed the starter there was oil on top of the Bendix part of the starter. I took my old starter to auto zone and they said it was good. So I put that back in bc the cheep starter the wire had broken from the solinoid.. I'm getting now nothing just a click. Fuel pump is running all lights and fan work. What's going on? At a loss
- Has thanked: 1502 times
- Been thanked: 3817 times
Have you tried the starter bypass to rule out the ignition switch and wiring?
You can also put 12 Volts directly into the small starter terminal with a wire by touching it to the poisotive battery terminal. Make sure you are out of gear and brake is on so you don’t run yourself over ( leave key out for this test)
Changed title to standard Mvs format
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Wonky contact on the little spade terminal connection is always a good place to look, too. Sometimes it can pretend to be making but still be too loose to pass all the necessary voltage.
