Using "Master Switch Repair" as a search term here at MVS, you'll come across this link:Trish wrote:how do i clean it then?
https://www.matthewsvolvosite.com/2009/0 ... o-s70-v70/
"Who's Yer Buddy? " Search is yer buddy!
No, something(s) are up there.jimbassist wrote: ↑02 Nov 2021, 10:12 I just changed out my 2000 S70 ignition switch on the left side of the steering column and the dash lights stay on when I reconnect the negative battery post. It also wouldn't allow my key to be inserted. I took the negative post back off unplugged the ignition switch and re-installed it reconnecting the negative post and same except the key can be inserted and turned. I have the part still on but unplugged it to conserve the battery. Is this a part of the manufacturers control?
