P80 headlights Possible to Remove Headlight Reflector, rechroming discussion 8628402 8628403
Both krylon and rustoleum make a silver mirror surface spray, application five light coats with one minute in between, but the reflective surface is at the first layer / glass interface , so I’m not sure that will work on our plastic reflectors. Also in the high heat environment, I wonder how long the finish would hold up.
PSA by the way. Open up those headlight twist covers and inspect your headlight wires periodically
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I had similar heat damage to the H7 bulb wires on my Mercedes. It was caused by a bulb filament which was disconnected but still sometimes working. This increased the resistance on the wires, generating more heat, causing damage. I was able to buy new H7 bulb socket and wires ("pigtails") but haven't soldered them in yet. I wonder Volvo offers similar harnesses, or if you could just get generic ones.
I asked my powder coating shop about chroming the plastic reflectors and they can't do it. I'll look in to it more. Unfortunately, buying cheap aftermarket replacements costs less than reapplying chrome. Surely the aftermarket ones must be worse in other respects due to their low price.
FireFox31
How were the headlight on Jane Bond, the 00 70 donor car? I can pull those for you
- Has thanked: 987 times
- Been thanked: 1075 times
I believe there is good chrome and cheap chrome and they never meet in the middle.FireFox31 wrote: 10 Nov 2021, 21:16 I had similar heat damage to the H7 bulb wires on my Mercedes. It was caused by a bulb filament which was disconnected but still sometimes working. This increased the resistance on the wires, generating more heat, causing damage. I was able to buy new H7 bulb socket and wires ("pigtails") but haven't soldered them in yet. I wonder Volvo offers similar harnesses, or if you could just get generic ones.
- FireFox31
Do you mean the one you picked up from me? Those headlights are rather unsafe, marginally luminous. I could use them as rehab cores if I figure out how to do the chroming. I have a few even worse condition ones for my first tests. Really, I'll probably never get to this, but I'd sure like to. Seems good to preserve true, OEM parts.abscate wrote: 11 Nov 2021, 04:22 How were the headlight on Jane Bond, the 00 70 donor car? I can pull those for you
FireFox31
There are claims that HVAC tape makes a decent reflector and can be easily applied. Sounds fishy but I might fire up Abscates Testing Lab
Ok I picked up some 3M reflective HVAC tape
I will be testing a new TYC UNIT and a taped Volvo headlight on the same target on Monday unless I really get jammed for time
Here is a brand new TYC pattern from Evita
- Has thanked: 2199 times
Your gas gauge looks like the ones in our cars when I go to use them. I figured I am the only one who knows how to open the flaps and fill them!
- Has thanked: 2856 times
- Been thanked: 1332 times
Man I wish I lived close. I'd rig up a passable(ish) scientific test for this A/B. Large white board, same exact distance A/B, same tripod-mounted DSLR to meter spot (center) and center-weighted, night time both A/B, closed garage door to minimize/eliminate background light sources. Everything. Throw the variable elimination kitchen sink at it.abscate wrote: 14 Nov 2021, 04:54 Ok I picked up some 3M reflective HVAC tape
HVAC tape makes a lot of sense to test.
