I’ve had trouble fitting 4 Conti serp belts on pre 1999 p80s this summer
In each case , with the tensioner pinned in full release position , I was unable to install the belt over the power steering pulley ridge with strong hand pressure or even using a wooden dowel as a pry tool.
Last job I had owner buy both the Volvo and the Conti and the Volvo was tight but easier.
I have actually had to remove the tensioner ideally in GrunHilde , install the belt , then work the tension back into place around the belt
Is this normal for the -1998s?
I spent an hour trying to mount the Conti belt last time
Afterwards , here is how the Volvo tensioner rides , can some 1998s take a pic of the tensioner and post here please ?
P80 serpentine belts Conti Volvo 2021
- RickHaleParker
- Been thanked: 977 times
It is a new belt. The tensioner will move down as the belt gets broken in.abscate wrote: 10 Nov 2021, 06:42 Afterwards , here is how the Volvo tensioner rides , can some 1998s take a pic of the tensioner and post here please ?
1998 C70 with Continental belt , 18,000 miles.
Active
Past
Past
- Has thanked: 311 times
- Been thanked: 817 times
I have owned several 95-98 and changed several serp belts on them. Most were difficult/tight to install but I never had to pry with a lever. I can remember one I did after head work that was easy, slipped right on; it was memorable because it was so easy. I've bought almost exclusively Conti though I remember I once picked up a Dayco locally so that I didn't have to wait for mail order.
- Has thanked: 2199 times
I can honestly say I have never found them easy to fit. They are usually a challenge to fit.
I’m probably spoiled by the 1999 version which is really easy.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 672 times
- Been thanked: 163 times
Yo,
Ifight some many times with these f*cking belts.. Finally, the easiest way was to install the belt and finish by the part designed by the red arrow : it goes as in a brief !
Manov
Manov
For sure, idler pulley is the last one on
Of course. If you fit ps last you have to stretch past both the pulley lip and the depth of the ribs. MAybe I should look up the actual procedure
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
You too?
I bought a new Continental belt, 9186352, and used the recommended new routing. I never did get that damn belt on the engine. Fought with it for half an hour before tapping out. Even with the tensioner prybar'd over onto it's hard stop, I swear that belt's an inch-and-a-half too short.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
No, don't refer to the manual. The noble manly way is to fight till the end. For no reason whatsoever.abscate wrote: 11 Nov 2021, 15:17 Of course. If you fit ps last you have to stretch past both the pulley lip and the depth of the ribs. MAybe I should look up the actual procedure
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 840 Views
Last post by cn90
- 16 Replies
- 3735 Views
Last post by Clemens
- 9 Replies
- 2385 Views
Last post by erikv11
- 19 Replies
- 6413 Views
Last post by matthew1
- 59 Replies
- 33106 Views
Last post by Twarr12000
