If the bolts are not rusted. I'm hoping they are going to be ok as I replaced the 2 slider bolts maybe 3 years ago. Actually, they may be newer than that as our son had a prang in it maybe 2-3 years ago and it got a new bumper cover.
- Has thanked: 1853 times
- Been thanked: 1714 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
There are only 2 bolts holding the bumper. The rest is plastic push pin clips and a couple of torx screws. I can do my bumper out and then back in with eyes closed, in under 5 minutes. It is that easy.
wch2032
- Year and Model: 06 XC70
- Has thanked: 10 times
I replaced my oil cap gasket (which was pretty hard) and upper engine mount (rubber insert moved freely inside). Now I'm thinking I need to do the strut brace mounts as they seemed pretty soft–or is this normal?
Also thinking of swapping out the rear shocks. Does anyone know if I need a spring compressor for this on a 2006 XC70?
06 XC70 - 251K
- Has thanked: 1507 times
- Been thanked: 3823 times
Big pry bar to pull the control arm down. I stood on a 6 foot bar with big fat guy on the end of a 4-5:1 lever to get this donewch2032 wrote: ↑12 Nov 2021, 23:41 I replaced my oil cap gasket (which was pretty hard) and upper engine mount (rubber insert moved freely inside). Now I'm thinking I need to do the strut brace mounts as they seemed pretty soft–or is this normal?
vtl
They are soft by design, to keep vibrations under control.
Yes. You still can take the whole assembly out w/o compressor, but changing the shock would require using a spring compressor.
This type of compressors works very good: https://www.ebay.com/itm/165021127842?h ... SwBgRhKHhC
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
- Has thanked: 293 times
- Been thanked: 765 times
I used really heavy duty tie-down straps and cinched the rear control arms together and down, did not use a pry bar except when popping out the shocks. Yes on compressor. 07 XC70.abscate wrote: ↑13 Nov 2021, 01:52Big pry bar to pull the control arm down. I stood on a 6 foot bar with big fat guy on the end of a 4-5:1 lever to get this donewch2032 wrote: ↑12 Nov 2021, 23:41 I replaced my oil cap gasket (which was pretty hard) and upper engine mount (rubber insert moved freely inside). Now I'm thinking I need to do the strut brace mounts as they seemed pretty soft–or is this normal?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
This is spot on. I just changed the washer pump on my S60, had to unhook the bumper and pull away on passenger side to do it. Seems like a hassle until you see how it's done. Then you get in there and it's super easy.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
Took out radio for the 4/5 time for intermittent fault of no display.
Discovered my sun glasses are polarised, re instal radio.
’User error - no fault not found’
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
We used to diplomatically file those under OHIO
OPERATOR HEAD IN ORFICE
