We've spoken a bit about steelies in the Crickets thread.
BaT Megathread
- Has thanked: 2658 times
- Been thanked: 1248 times
Re: BaT Megathread
Oh but they do... "they" being "someone out there". You can always have wide steelies made from everyday steelies at a local (good) wheel shop if you can't find them new/used/homebrewed.
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 331 times
- Been thanked: 242 times
Oh man, this is it. That is what I'm looking for!matthew1 wrote: ↑15 Nov 2021, 09:47 Oh but they do... "they" being "someone out there". You can always have wide steelies made from everyday steelies at a local (good) wheel shop if you can't find them new/used/homebrewed.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
That photo would be fantastic no matter the wheels, but those deep steel wheels make it special.
But to get back to your question, wheel shops not only make wheels wider (or narrower I'm sure), but they also make them larger, like a 16-inch into a 17 or 18-inch wheel.
- BlackBart
- Has thanked: 927 times
- Been thanked: 885 times
Over the last few years, I've found that that has gone from a common practice amongst rodders and wheel shops, to very rare. Hard to find a wheel shop who will do this now - maybe lack of demand, maybe liability.
1 - You can either "band" them, meaning the barrel is cut in two halves and then a steel "strap" is fitted (using a lathe set-up) and tack welded and squared up. The band can be on the inside or the outside of the wheel, producing very different offsets.
or 2 - You carefully cut the welds holding the disk or hub to the barrel or rim. You find another rim / barrel / shell with the dimensions you want (it has to fit your disk) and you tack weld the disk in the rim with the offset you want. Companies till make empty steel barrels of different widths and diameters. Many junkyard American wheels can have the exact dimensions you need, you just change the centers.
https://www.speedwaymotors.com/15-Inch- ... 8,218.html
If you search for banding videos, you might get a couple of guys in an open shed with a dirt floor, working with a lathe or just an old axle / hub and welder.
For my Alfa, I lucked upon a guy selling (cheap!) a widened set an inch and a half wider than stock, made by a well regarded machine shop in NC back in period. They still have the logo stickers inside the wheel. The lips have a few good dings but they seem to be straight.
These guys in CA apparently still do it -
http://www.stocktonwheel.com/powder_coat.html
https://detroitsteelwheel.com
http://thewheelsmith.net
Far away...
http://dblackbox.com/en/steel-wheels-widening/
This post said a 240 on widened Peugeot wheels.
Far away...
- Has thanked: 1507 times
- Been thanked: 3822 times
They haven’t been the same since Franco Harris retired.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
$25k... and there's over a week(!) left. My goodness.foggydogg wrote: ↑21 Nov 2021, 17:51 Uh-oh.
https://bringatrailer.com/listing/1995-volvo-t5-r-4/
And,
Yellow !
Autoshifter though.
This is my dream Volvo.
- foggydogg
My yard is full, and my bank account, not so much. I'm just a spectator here.matthew1 wrote: ↑21 Nov 2021, 19:01$25k... and there's over a week(!) left. My goodness.foggydogg wrote: ↑21 Nov 2021, 17:51 Uh-oh.
And,
Yellow !
Autoshifter though.
I bet Jim would've chimed in, too.
I think the guy who went heavy early is a long-time member of the Volvo crowd on BaT; we'll see how this plays out.
- foggydogg
'06 S60R manual in Houston
https://bringatrailer.com/listing/2006-volvo-s60r-9/ Looks clean and well sorted, but it seems the S60s don't age well in the used market.
