2004 V70 NA, timing belt broken
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
Long story. Several years ago, I blew the timing belt on my '04 V70. Had it towed home, put it under the barn and transferred the plate to another Volvo. The short is I don't remember a lot about behavior when I broke the belt. I don't think I heard a lot of noise. I still have the car and like it's looks. Are there any tests I can perform to determine the extent of injury without putting in a new timing belt? Valve repair I might do, a busto piston puts a different light on things.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Has thanked: 1504 times
Been thanked: 3817 times
I have a spare old timing belt just for that purpose. You could set it up and turn the engine over to listen for broken stuff. It’s rare to break pistons, just bent valves.
Either way, head comes off to rework, so I think that’s next step
Pm me your address if you want me to send you that belt, after we confirm fitment.
It’s off my 1999 T5, pretty sure it fits a P2
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
If you can get your hands on a bore scope you can probe the spark plug holes and look for ding marks in the tops of the pistons.
Faust
Post by Faust »
The bore scope. I have one, should have thought of that.
2004 V70
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
You almost always have dings from the valves hitting. I usually grind them down not to create any hot spots.
BMW 540i 2002
S70 Base 2000
Take a look at my T5 rebuild thread to see pictures of top of clean pistons. I’ve seen dings and semi circular marks that are standard, but my T5 didn’t have them
