There is a table of compatibility in VIDA.
With your Chassis number ( Last six digits of VIN ) and the ECM part number you should be able to figure out which power units will work. Is you car a 854 or a 855?
The D+ supply includes a change in the wiring harness. The part number on your ECC should let you determine if you have the D+ upgrade, keep in mind some, of the MY 1994 where manufactured in late 1993.
This should solve the mystery of what all the power stage part numbers are.
Determine which power stages are compatible with you car.
