-2004 won't crack. I found the pin comparison code, it is "buggy": yields only a couple of CPU ticks of difference, which is not possible to detect over CAN.Canadian Moose wrote: ↑01 Jan 2022, 15:24 That's a good catch. I must've changed that setting manually last year when I was messing with my 2002 CEM and never changed it back. Gonna try to start at third position and see if it's able to do it. Looks like first 3 are 79 92 and 97.
You CEM-L has a "bad" code placement in flash memory. I speculated a few dozen pages back why some CEMs are harder to crack than others, that may be due to CPU executing code from flash, which has memory row/line access latency. On some CEMs the third byte compare routine does not yield extra latency, or enough extra latency to be detected over CAN.
You can always stock up enough beer and crack with CALC_BYTES 2, not 3. Within like 18 hours it will crack with brute-forcing the last 4 bytes.
