Vida CEM swapping
eltoro
Year and Model: XC60 2011
Re: Vida CEM swapping
Post by eltoro »
RickHaleParker wrote: 17 Dec 2021, 20:00 This is what I came up with for P3 Bench setup.
Teensy loaded with VTL's P3 branch. Do not use the Main branch.
Connector C5 (Black connector next to the Blue connector )
  • PIN : Function , ( Comment )
    C5:1 : Battery Power (+) , ( 12V which is marked 30+ on a EWD )
    C5:2 : Battery Power (+) , ( 12V which is marked 30+ on a EWD )
Connector C1 ( Green Connector )
    C1:30 : MS-CAN (+) , LS-CAN H ( Green wire )
    C1:31 : MS-CAN (-) , LS-CAN L ( White wire )
    C1:54 : Battery Power Ground (-) , ( VTL is grounding some place on C3 but C1:54 is the official power ground. )
    C1:63 :15+ , ( Key on. VTL is not using this but Vdash requires the key to be on. Apply +12V for Key on conditions. )
Connector C3 ( Blue Connector )
    C3:6 HS-CAN (+) , HS-CAN H ( Green wire )
    C3:7 HS-CAN (-) , HS-CAN L ( White wire )
Finally, I managed to finish the bench setup.
I did add second ground connection:
Connector C2 (Brown Connector)
C2: 65 Power Ground
I am not sure if C1:63 is needed? VIDA states it is Relay 15-feed, voltage feed. It does not seem to change anything now.
How do I know CEM is ready and powered on for CAN messaging?
When I power on the CEM, I'll hear a relay clicking sound, but then nothing. Some of the fuses are powered on but not all, kind of what I would expect.
I do have the Teensy connected to CEM but I do not get any CAN responses, all messaging times out. (Teensy HW not verified)
When I measure the CAN lines, there are no expected voltage levels when only the CEM is powered. When Teensy is powered I'll right voltage levels from CAN lines. 120-ohm termination resistors are on both CAN busses.
I do have an old lab power supply that should be capable of at least 12V 2A, power consumption seems pretty low ~10-200mA (rough reading from the analog meter). What is the expected power consumption on the bench setup?
Any ideas about what is missing?
When should the CEM start a message on the CAN busses?
Is there some need for KVM wakeup? CAN message or some other signal?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
eltoro wrote: 10 Jan 2022, 00:21
C2: 65 Power Ground
Good catch, I missed the C2:65 Power Ground
I put C1:63 up there so that people would know how to simulate switching the key on.
It is DIN terminal type 15 not "Relay 15". The 15 comes from Standard DIN 72552.
DIN = Deutsches Institut für Normung e.V. ( English: German Institute for Standardisation ).
There is suppose to be 120ῼ on both ends of a CAN bus. Measure the resistance across a 120ῼ with the cracker connected. If it is 60ῼ it is terminated correctly. Two 120ῼ in parallel = 60ῼ. If it measures 120ῼ a second 120ῼ on the other end of the CAN Bus is due.
VTL is the only one that has done this. I don't have any P3 CEMs to experiment with.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
RickHaleParker wrote: 10 Jan 2022, 06:18VTL is the only one that has done this. I don't have any P3 CEMs to experiment with.
P3 is simpler: no nanoseconds hunting, just brute force. Once everything is wired correctly, no glitches, etc, it will eventually crack.
RickHaleParker
vtl wrote: 10 Jan 2022, 06:40 P3 is simpler: no nanoseconds hunting, just brute force. Once everything is wired correctly, no glitches, etc, it will eventually crack.
Should this sequence work?
  • 1. Load Sketch P3.
    2. Turn Cracker off.
    3. Connect the Cracker to the CEM.
    4. Power up the CEM.
    5. Start the Cracker.
RickHaleParker
eltoro wrote: 10 Jan 2022, 00:21 I do have the Teensy connected to CEM but I do not get any CAN responses, all messaging times out. (Teensy HW not verified)
Post some close up high resolution pictures of your hardware. We will see if we can spot potential problems with your HW.
Did you read the discussion on Common Ground?
vtl
Post by vtl »
RickHaleParker wrote: 10 Jan 2022, 06:49
4. Start the cracker
5. Power up the CEM when the cracker says:
Putting all ECUs into programming mode.
=== CEM-on-the-bench users: you have 5 seconds to apply CEM power! ===
That's for the case when the CEM does not see enough CAN devices on the network. If I understand correctly, with DIM connected and maybe something else, CEM does not go into standby mode.
RickHaleParker
vtl wrote: 10 Jan 2022, 07:16
Ok .. you will need a Serial Terminal that reconnects automatically when you turn on the cracker. Some Serial Terminals will not reconnect after communication is lost ( Step 3 ).
    2. Setup communication with the Serial Terminal.
    3. Turn Cracker off.
    4. Connect the Cracker to the CEM.
    6. Power up the CEM when the Cracker says:
Is there some verbose notification that will tell you startup was successful?
Niels83
Year and Model: 2008
Post by Niels83 »
Soooo... I've been going through this threat with some leaps. I want to get the pin of my 2006 C70-II. I have a DiCe and I found this so far: https://github.com/vtl/volvo-cem-cracker
But how do I get it to run through the DiCe? I also saw something called Teensy. Do I also need that next to the Dice? Sorry for asking questions you guys obviously must have discussed, but I can't see it in the opening page or by using the search option in this threat.
RickHaleParker
Niels83 wrote: 10 Jan 2022, 08:43 But how do I get it to run through the DiCe? I also saw something called Teensy. Do I also need that next to the Dice?
DiCE has nothing to do with this. You build the interface using a Teensy 4.0 development board. Look in the folder doc in the vtl/volvo-cem-cracker zip file.
eltoro
Post by eltoro »
I did verify my Teensy HW HS CAN, sending and receiving is working even connected to CEM.
My CEM remains silent. There is no activity on CEM, except some clicky noise. When I try to power on the CEM separately I don't see any voltage levels changes on CAN lines (using multi-meter voltage measurement, I don't have an oscilloscope).
Is it so that it should not need any other messages or voltage signals to wake up the CEM?
Another thing is that P3 branch does have k-line serial3 codes used, is it the merge issues or should there be some HW connections from serial3 to CEM?
