I know it’s my fault for not using an OEM part. Put a Volvo PEM in today 40F outside started and ran fine. Weather forecast tomorrow is -15F windchill. Fingers crossed it starts.
2004 S60 First cold day of the year, no start issue.
nucci480
- Year and Model: 2004 s60 2.4
- Has thanked: 10 times
- Been thanked: 2 times
Re: 2004 S60 First cold day of the year, no start issue.
- Has thanked: 1505 times
- Been thanked: 3818 times
The jury has contemplated the evidence against the Dorman PEM and will issue a verdict…..short
Y
Y
nucci480
Started -5F this morning! I believe the issue has finally been resolved. Dorman PEM was the issue, replaced with genuine Volvo PEM and started right up. I guess I learned my lesson to buy OEM Volvo.
I don’t know how mechanics shops stay in business with the parts supply chain of today
Nuncio, can you pull your part number and post it here please, for cross reference?
xray978
- Year and Model: 2003 V 70
You helped me. Thanks. My six-month-old Dorman PEM also did not work below freezing. After I saw your posts I kept the Dorman PEM inside overnight and in the morning my V70 started right up. I installed a used Volvo PEM today and the problem is resolved. Were you able to get a refund for the Dorman PEM? I too spent time and money on other things in the belief that the problem could not be with the new PEM because it was new.
nucci480
Ya I was able to get a refund from dorman because it was a Amazon purchase and was under warranty. I made this thread in hope that it saves other people. I called dorman and made a complaint they apparently “noted”. You should call dorman also and explain your issue.
