2001 V70XC - Starting with Blackstone Oil Report
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
Here is a collection that lists all repair on our 2001 V70XC search.php?keywords=2001+V70XC&terms=al ... mit=Search, AND the 200,000 Miles Makeover viewtopic.php?f=9&t=92790&hilit=2001+V70XC.
The Blackstone Lab sent me following oil report; are these vitals a good indicator for the engine to reach 250 - 300K without failing?
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 17 times
Been thanked: 33 times
Post by ignatz »
My 01 V70 2.4t had a delayed oil light that would be OK if driven daily, but if I let the car sit for 2 or 3 days, the oil light would delay more and the engine would slightly rattle as it picked up oil pressure. I sent an oil sample to Blackstone and they also mentioned that 7ppm lead in my sample wasn't normal. Mine was an o-ring on the oil pickup tube where it goes into the block.
A final test after my repair shows my lead level lowered to 3ppm. An improvement over the 7ppm.
How's your wagon sound on startup and does the oil light go out quickly? PS, all my other Volvo's that I had oil sampling done from Blackstone came back with lead levels at 1 ppm.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
xHeart
Post by xHeart »
ignatz wrote: 24 Jan 2022, 14:54 My 01 V70 2.4t had a delayed oil light that would be OK if driven daily, but if I let the car sit for 2 or 3 days, the oil light would delay more and the engine would slightly rattle as it picked up oil pressure. I sent an oil sample to Blackstone and they also mentioned that 7ppm lead in my sample wasn't normal. Mine was an o-ring on the oil pickup tube where it goes into the block.
The oil lamp goes out immediately after the engine starts. The lubrication systems - oil pan, seals, pick up, oil cooler, oil pump, PCV, etc were serviced not too long ago, around 190,000 miles, more here viewtopic.php?f=9&t=61449&hilit=2001+V70XC
ignatz
Post by ignatz »
Just keep driving!
2002 V70 2.4
2005 S60 2.5t awd
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
So, you've had oil pressure problem that wore rod bearings, you had the oil sump dropped to address the issue, and you didn't replace your old rod bearings? It was cheap (a set of Glyco is under $60) and super easy, sump removal is 80% of rod bearings job.
ignatz
Post by ignatz »
I tried to post my last report, but I couldn't figure out how to fuzz out my phone number and such.
4-1-2018 153,000 miles......7ppm first oil sample
11-25-2018 162,000 miles.....3ppm first report after fixing oil pickup
8-24-2019 172,000 miles.....1ppm second report shows good
I'm at around 197,000+ miles and will do another oil sample this summer. If the lead levels start going up, I would do rod bearings.
But right now its sounds OK while starting up.
I just didn't want to do rod bearings at the time I dropped the pan, but rod bearings could be in my future.
2002 V70 2.4
2005 S60 2.5t awd
xHeart
Post by xHeart »
vtl wrote: 28 Jan 2022, 06:27 So, you've had oil pressure problem that wore rod bearings, you had the oil sump dropped to address the issue, and you didn't replace your old rod bearings? It was cheap (a set of Glyco is under $60) and super easy, sump removal is 80% of rod bearings job.
Love the science of oil report, vtl!
I switched my cars to Pennzoil EURO 5W40 some 4 years ago; would report be different if the engine oil was a synthetic 10W30 as recommended in owner's manual?
vtl
Post by vtl »
xHeart wrote: 29 Jan 2022, 08:55 I switched my cars to Pennzoil EURO 5W40 some 4 years ago; would report be different if the engine oil was a synthetic 10W30 as recommended in owner's manual?
Yes. Thicker oil, less mechanical wear, less metal in oil.
I've got two engines from two 2005 XC70 to compare, both taken apart at 220k miles. One was mine, I bought it at 80k miles and used highest possible quality oils all the time, quickly moving from 0/5w30 to 0/5w40 and last few years to 10w40, topping up with whatever 15w40 diesel oil was available at the gas station. The other engine was from typical neglected car. But it's the same engine model, same age, same mileage.
I measured the bore wear, my engine had it about 1/3 of the other engine. Rod bearings in the other engine were worn, my were almost like new. Other engine had cylinder head moderately warped, my had only couple of depressions (lower areas) between combustion area and cooling channels. Other engine had valve stems and valve guides wear, mine had it beyond detection. And other such things.
Don't know about other engine's history much, but I was beating my engine.
Making long story short: thicker, higher quality oil reduced mechanical wear and thermal stress drastically. But you still have to replace valve seals timely, around 150k miles ;)
xHeart
Post by xHeart »
vtl wrote: 29 Jan 2022, 09:53 I measured the bore wear, my engine had it about 1/3 of the other engine. Rod bearings in the other engine were worn, my were almost like new. Other engine had cylinder head moderately warped, my had only couple of depressions (lower areas) between combustion area and cooling channels. Other engine had valve stems and valve guides wear, mine had it beyond detection. And other such things.
Thank you VTL!
Is this the valve stem seals you're referring to for a 150k miles service? If so, then, our Robert DIY channel has a four-part step-by-step video on valve stem seal replacement -- I'll look through it for the assessment of task.
I believe, Pete had a discussion on rod bearing -- I'll search.
Has thanked: 1501 times
Been thanked: 3812 times
I would not use an 8 ppm lead as a marker for bearing wear. That’s 8 parts per million! In your roughly 6 liters of oil, thst means you have a total mass of
6 liters ~ 4000g * 8E-6 = 32 milligram of lead. That’s not much from the mass of lead in the main bearings, rod bearings, small end bearings.
