Vida CEM swapping
Sh4rp
Year and Model: See below.
Has thanked: 2 times
Post by Sh4rp »
Here are the Dumps from my 08690720 Bench CEM.
2004 - V50 T5 AWD M66 - Flint Grey
1996 - 850 T-5R M56 - Dark Olive Pearl
Sh4rp
Post by Sh4rp »
Sh4rp
Post by Sh4rp »
Sh4rp
Post by Sh4rp »
Sh4rp
Post by Sh4rp »
Here are the dumps for the not crackable CEM. - Sorry for double posts... MVS threw some SQL error.
EEP (L).txt
(2 KiB) Downloaded 95 times
EEP (R).txt
(4 KiB) Downloaded 86 times
Flash (L).txt
(2 MiB) Downloaded 80 times
Flash (R).txt
(2 MiB) Downloaded 84 times
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Cleanup on aisle CEM
Active
Past
AA2020
Year and Model: 2007/ V50
Post by AA2020 »
The order is 5, 2, 1, 4, 0, 3. Could you try it with shuffle order set to 2?
Not working.
P1_Not_OK_02.txt
(143.05 KiB) Downloaded 95 times
RickHaleParker
AA2020 wrote: 09 Feb 2022, 04:56 The order is 5, 2, 1, 4, 0, 3. Could you try it with shuffle order set to 2?
Not working.
5, 2, 1, 4, 0, 3. is shuffle order 2.
unsigned char shuffle_orders[4][PIN_LEN] = { { 0, 1, 2, 3, 4, 5 }, { 3, 1, 5, 0, 2, 4 }, {5, 2, 1, 4, 0, 3}, { 2, 4, 5, 0, 3, 1} };
-------------------------------------------------------------------- Order 0 ---------- Order 1 ------------- Order 2 ---------- Order 3 -------
{ 8690720, CAN_500KBPS, 2 }
Just edit the highlighted to change the shuffle order for 8690720.
Or you can down load the latest code. Shuffle order has been set back to 0 because P1 owners where having trouble with shuffle 2.
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 09 Feb 2022, 06:57 Just edit the highlighted to change the shuffle order for 8690720.
He did already:
Code: Select all
13:11:47.497 -> Part Number: 8690720
13:11:47.497 -> Searching P/N 8690720 in 50 known CEMs
13:11:47.497 -> CAN HS baud rate: 500000
13:11:47.497 -> PIN shuffle order: 5 2 1 4 0 3
13:11:47.497 -> CAN high-speed init done.
The problem is CEM P/N 8690720.
RickHaleParker
vtl wrote: 09 Feb 2022, 07:32 The problem is CEM P/N 8690720.
8690720 will not crack on 0 or 2?
Active
Past
