Nearly 50 percent of designers have less than average experience.
P80 P2 Coolant pipe o-ring & install 976045 Topic is solved
- Has thanked: 1511 times
- Been thanked: 3827 times
Re: P80 P2 Coolant pipe o-ring & install 976045
- Has thanked: 305 times
- Been thanked: 517 times
Great! Have you gotten everything reassembled and leak-tested?
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Still need to reinstall the turbo before I can check for leaks, but all looks good so far. Also did the firewall heater hose coupling bypass. Wasted some time running around looking for distilled water. Must be a supply chain issue
. Should have everything buttoned up today.
Question: Is it true that with the crank at TDC and timing belt off, that the camshafts can be rotated as needed without worry ?
Just wondering for future reference in case I need to change the timing a little more due to the NA cams.
1999 V70 GLT
1999 V70 GLT
The timing mark on the crank is not TDC, the number one piston is near top and will hit valves if you rotate the cams full turnsSveedy wrote: ↑13 Feb 2022, 08:32 Still need to reinstall the turbo before I can check for leaks, but all looks good so far. Also did the firewall heater hose coupling bypass. Wasted some time running around looking for distilled water. Must be a supply chain issue. Should have everything buttoned up today.
Picture of the pistons at the crank mark in this thread, page 5 , Jan 27 2021 post
viewtopic.php?f=1&t=96254&hilit=Resurrection&start=40
- Sveedy
This is what I was talking about...answered my own question.
viewtopic.php?t=63740
1999 V70 GLT
1999 V70 GLT
- Sveedy
Found a small water leak under the front of the engine. I checked everything over, and it looks like it's coming from the thermostat area. I don't see where exactly, but below it is the highest point that I've found any water. Most importantly, it's not the water pump or coolant pipe. The thermostat housing, though clean, had a lot of pitting where the O-ring seats. I'm guessing that's the issue.
I was hoping it might have been a loose hose clamp, but .....
Still all and all, it's all good.
1999 V70 GLT
1999 V70 GLT
Well at least it should be easy from here!
- Has thanked: 1858 times
- Been thanked: 1718 times
Check if the leak is the thermostat seal ring. Was the thermostat a Volvo part you used. If aftermarket, I have had issues with some of the seal rings being too thin and leaking.
Just documenting the taper and chamfer on the water pipe here
- 575D6FD4-3542-461B-AEEB-588AF35E8077.jpeg (4.18 MiB) Viewed 436 times
- A07C12F9-10C8-4FAC-BC03-D931E050BE87.jpeg (3.49 MiB) Viewed 436 times
- 984 Views
Last post by volvodork
- 4820 Views
Last post by darrylrobert
