Fluctuating electrical power?
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Re: Fluctuating electrical power?
Post by 454cid »
scot850 wrote: 19 Feb 2022, 19:32 Been a long time since I swapped the motor out on an 850 and seem to recall a small level of complexity greater than the V/S70 due to the knee brace being in the way. Maybe I am confusing it with a 98 V70. Later cars don't have that.
V70 heater fan (1).pdf
Hope this helps. If it is not ok to post this then please remove.
So, that black thing marked with the SRS sticker isn't "live" in any sense? I thought I saw wires going to one end of it, but I have not looked at it closely, yet. The pdf mentions "...and SRS passenger airbag module:Disassembly ."
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1502 times
Been thanked: 3817 times
I believe the black shield has the srs sticker , the actual airbag is in a silver case.
The recirc damper motor comes off attached to a mount which can then be removed off the car easily. The mount has a single screw accessible under dash
Has thanked: 1843 times
Been thanked: 1710 times
The airbag is attached to the top section of the dashboard. The sticker is just an information sticker. Like anything, working under the dash, disconnect the battery prior to working there for safety.
There should be I think 3 nuts on studs holding the brace in place. 15mm I think. on the RHS footwell, 2 nuts in recesses on the right end and only one on the left. The other hole has a ratchet type unit in which makes it a little tricky to remove.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
The sticker just announces that the knee bolster is part of the 'system', I saw it described as 'anti-submarine' protection. Race cars use a crotch belt for the same reason.
Like Neil, it has been a while since I had that part of the car under inspection, but the recirc lever wasn't any large job. The blower motor has a wire bundle across it though, and the tape wrapper is gonna be slimy. It just gets the wire ties cut and pushed aside.
Hope you get a spell of good weather.
454cid
Post by 454cid »
I fiddled with the arm yesterday, and I don't think it'll be too bad getting it off, if I don't drop the arm and have to try to fish it out. I've got a new one on order, along with headlight wipers from FCP.
Thankfully the blower seems to be okay for the moment, which gives me a bit more time.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
do the fluctuations include dimming of the dash lights or head lights depending on the system you run? I have had this issue due to a loose battery connection and bad battery terminal. are any wiper motors seized? my rear wiper drained a battery recently when left on while trouble shooting something else. hope this helps
2008 S60 2.5T Auto (Sold)
454cid
Post by 454cid »
yanga001 wrote: 22 Feb 2022, 06:01 do the fluctuations include dimming of the dash lights or head lights depending on the system you run? I have had this issue due to a loose battery connection and bad battery terminal. are any wiper motors seized? my rear wiper drained a battery recently when left on while trouble shooting something else. hope this helps
Yes I noticed the lights dimming when it happened at night.
The wiper motor is fine.... used the wipers today as it was raining on my drive. Unfortunately, I have a minor leak someplace because I found water beaded up on the carpet, and in the floor mat when I got to work.
I believe the battery connection is okay. I suppose I could pull it apart and double check, but I could not move the clamps by hand. I installed a new battery when I bought the car... before I actually got the car home, because the old battery was toast.
I have not had this issue for several days now, but I suspect it'll return.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
FCP order arrives tomorrow/today/Wednesday..... hopefully I can get that recirculate arm installed. I messed with the button tonight while watching the shaft with a flashlight. Does this thing calibrate itself? I heard a clicking noise, like maybe a gear tooth was skipping each time I flipped the switch. I could see the shaft turning back and forth, but I wonder if that's why the original arm broke. I'd hate to install the new arm and immediately have it break.
I'm tempted to pull the actuator and take it apart.... if it'll come apart?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Just make sure you know where the arm is when you fit it. If I recall it can only be fitted one way.
Make sure there is no debris in the cold air flap area that may cause it to bind.
The actuator is fairly easy to remove and you can then see is better. Leaving the cable attached and you can see if it is moving ok. You can also manually move the operating leaver for the cold air flap and see if it moves easily.
The intermediate arm is 25 year old plastic and they break with age. I think I have replaced them on every P80 I have had at some point. I now have a few spares just in case.............!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
Didn’t someone have a post about 3D printing
this part a few years back? May have been VS or SS.
