2006 S60 2.5T AWD - Radiator advice
justanotherhumanoid
Year and Model: 2006 S60
Has thanked: 7 times
Been thanked: 17 times
Post by justanotherhumanoid »
Neil,
Think I answered your other questions in the other thread, but regarding the thermostat, there's more to that than the radiator connection. On my car it was a moderate pita but I was doing a whole bunch of overlapping maintenance so it all kind of worked out (like I think I loosened up the power steering pump and had the serp belt off, and still the screw on the bottom is a big pita even if you don't accidentally drop it into the abyss under the intake...). If it's still working alright, I'd consider just leaving the thermostat for later.
Here's an idea of what you'd be getting into, which might be the easiest way:
viewtopic.php?t=83473
2006 S60 2.5T AWD - Build Log
do88 intercooler, all aluminum radiator, XC90 aux transmission cooler, magnefine ATF filter, Snabb intake elbow & throttle body pipes, custom oval exhaust, rebuilt 16T swap, 17x8" team dynamics pro race 1.2 wheels, ipd sway bars, R brake swap, Hilton tune, sunroof shade that slides open when I step on the gas and closes when I stand on the brakes.
Has thanked: 2199 times
Been thanked: 1852 times
Many thanks of the thermostat swap info justanotherhumanoid. Typical Volvo. Can't just make a job simple and give proper access to do a job without dismantling half a car! I thought $45 CDN for a simple thermostat for a P80 was excessive. $180 CDN for a P2!! That is totally ridiculous!!
May hold off on that for now as the radiator swap is expensive enough.
