My son's 2008 S60 has developed a radiator leak. He is having to top off the reservoir every two to three weeks, so this job cannot be put off much longer. I have done a radiator job on a 1999 C70. I have read where on the S60 radiator lines need to be removed while taking it out through the bottom? The job was awful enough ion the C70 without that added step.
Is this going to be a requirement? With the C70 I did it while the car was up on ramps, dropped the sandwich through the bottom, decoupled the radiator from the intercooler and the condenser and then reverse to put it all back together. Is this the same for the S60?
Dreaded radiator swap advice 2008 S60
- RickHaleParker
- Been thanked: 977 times
That don't sound too bad. Can you see where it is leaking? You might be able to patch it with J-B Weld. Which would save a load of time and money.
Active
Past
Past
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Sure it isn't a heater core leak?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 4064 times
I don’t see how anyone can get a rad out of a Volvo up top. On a turbo model, much more work.
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
Yes, its clearly leaking down the side. Seems to be a re-occuring them with the volvos in my life!
The 1999 C70 was nasty, and I agree, I did not see a way to pull it through the top. Honestly, if you have a set of standard ramps, I am pretty sure that is what is used...twice, because I got a bum radiator the first time.
I have read where there are A/C lines on the S60 that need to be moved in order to drop the sandwich (and the radiator) down. Has anyone ran into that?
I've also considered running k seal. I have used it in a pinch before when dealing with a HG issue on two other vehicles, it allowed me to kick the can down the road to warmer days.
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
I don't like sealers in a cooling system. they usually don't fix it and then you've gunked up your heater core, etc.
That said, it sounds like you're either leaking at a tank seam or one of the trans cooler lines. Nothing will fix a seam leak but I have seen leaks at the transmission cooler fitting stopped by tightening the fitting a bit.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
I’m in Greg’s club on this one. Even squeezing a job Into the warmer months isn’t worth the hunk you put into your cooling System. If the leak is too large to tolerate by topping off, then get her done.greg850r wrote: 02 Nov 2019, 17:38 I don't like sealers in a cooling system. they usually don't fix it and then you've gunked up your heater core, etc.
- 101 Views
Last post by volvolugnut
- 872 Views
Last post by ovlov058R
- 14 Replies
- 3668 Views
Last post by bmdubya1198
- 82 Replies
- 13285 Views
- 1189 Views
Last post by jonslave
