Fluctuating electrical power?
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Re: Fluctuating electrical power?
As I recall, it moves one direction pretty quickly, maybe a two count, but returns something like a step motor, more like a ten count. Default is fresh air.
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 129 times
I got the new arm installed today. The side that connected to the push-rod was fairly easy. It took awhile to get the actuator end in place. I started off by trying to attach it rotated towards the fire wall, but ended up going the other way, and that worked better. The biggest issue was that with two hands, I needed two arms in the dash and couldn't see anything. I had to to it by feel.
It seems to open/close more with the fan on 4. I assumed the door was either open or closed, but apparently not. I'm thinking that "recirculate" may not entirely be recirculated air, just mostly.
I still have not had the fluctuating power issue again since I started this thread.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1502 times
- Been thanked: 3817 times
The door closes completely in recirc mode. You can check my lifting the cabin air filter and looking down at the door
454cid
So after mentioning that I've had no more power fluctuations, that changed after work. It did it in the parking lot. I stopped at a gas station, and shut off the blower, while sitting there idling.... lights were dimming, so I'm thinking it's not actually the blower.
My thought is too clean the main grounds, if I can find/reach them. I'm kind of leaning towards the alternator going out however. I wondered about the alternator having an OAP (fancy clutch pulley), but I don't think I actually have one on my car, and the symptoms don't really match up to what I read is typical (sounds, bouncing belt).
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
No free wheeling pulley until the 1999 model..the best year ever. Try monitoring the battery voltage from startup to idle, then 2500 rpm with no loads and with “ full loads - wipers , defroster, blower. High beams.
- foggydogg
There is a wire bundle attached to the positive battery cable, it goes under the air filter box and feeds the main power bus. They are a known issue, with corrosion hidden in the crimped connections.
454cid
Ok, so the OAP is sorta like the HVAC filter, then.... gets listed for the 850, but didn't actually appear until later cars.
Apparently threat of my Fluke "fixes" the problem. It did it a couple of times at the stop light on my way to the gas station, but as soon as I was underhood with the meter it was completely fine, no fluctuations.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1842 times
- Been thanked: 1710 times
It could be worn or sticky brushes in the alternator. Maybe time to pull it out and see if the regulator is worn out, or at least give it and the stator a good clean. It could be carbon build up in general in there.
454cid
I just saw this post. What is the fix for this, new connectors? Complete replacement?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
I think what foggydogg is talking about is what is called the B+ cable. It runs from the +ve battery clamp up to the fuse box. However, this is an issue on the V/S/C 70's that have a secondary kidney shaped fuse box in front of the brake master cylinder. 850's don't have that.
It is the smaller red wire (can't recall if it is a stranded one like the later P80's) from the clamp that runs to somewhere? I don't know on the 850 where that is.
On the later cars, especially the 99-00 models of P80 the are prone to melting inside the kidney shaped fuse box below where it bolts in.
I have had a look at 850 engine bay pictures and if you look on this link:
viewtopic.php?t=60592
it looks like there are 2 red wires running from the +ve battery terminal. The multi-stranded version is the one. Where the other end goes to I have no idea.
Certainly the whole cable in the pictures here look rough!!
- 692 Views
Last post by LanceALatte
- 514 Views
Last post by Ozark Lee
