VIDA 2014D_Repack install on Windows 10, any version.
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
RickHaleParker
Been thanked: 958 times
Re: VIDA 2014D_Repack install on Windows 10, any version.
Post by RickHaleParker »
LozinOz wrote: 28 Feb 2022, 21:14 ‘GetCommToolSettingsObject(…)DiagnosticsAllowed is not a function’ - I’m at a loss what to do now. I’ve rebooted PC tried more than once - sane message.
Which browser are you using?
If you are using Microsoft Edge install the IE TAB extension.
LozinOz
Year and Model: 2012 XC60 D5
Has thanked: 3 times
Post by LozinOz »
Thanks Rick
Yes was trying with Edge as saw supported with the IE Tab extension which I did install (or thought so - I will check) happy to use Chrome etc (which I’ll try) - would the browser cause that type of error?
Cheers
RickHaleParker
LozinOz wrote: 28 Feb 2022, 23:16 Yes was trying with Edge as saw supported with the IE Tab extension which I did install
Vida has a lot of dependencies. Including Internet explorer. IE TAB takes care of that dependency.
Try the IE hosting in the iso. VIDA:\Install\Utils\EnableIEHostingx64.reg . EnableIEHostingx86.reg if you have 32 bit version of windows.
Reboot and try again.
LozinOz
Post by LozinOz »
Thanks understand, I’ll try appropriate options & let you know - pretty sure I’m on x64 but have several PCs so best to check everything.
Appreciated
LozinOz
Post by LozinOz »
Hi Rick
That nudge did the trick - working fine now (I’d not correctly set up IE hosting I’m pretty sure - I redid that & retried - worked 👌
Thank-you so much, I knew I was close but without your help I’d still be scratching my head.
Cheers
Loz
Stu70
Year and Model: 2006 Sonic VR GT
Has thanked: 34 times
Been thanked: 26 times
Post by Stu70 »
I’m nearly in tears…
I cannot ‘unpack’ the patch.
I just get …
I have tried for seven days, bought another laptop , Recovered / restarted windows many times on my two machines. I am completely at a loss.
I delete the patch folders, I download again, I attempt to extract and …foiled again
On one machine I have Vida log in page but can’t enter any thing in ( which is what the patch is for) as I proceeded with all the install steps without fully completing step 4 ‘run the 2099 patch’.
I’m very sad - but a dab hand at restarting laptops and erasing everything.
RickHaleParker I need your guidance, I can follow step by steps but am a complete novice and not familiar with the ‘back streets’ of windows.
Am I even doing it right ?
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
Stu70
Post by Stu70 »
Deleted post - thought I had sorted.
RickHaleParker
Stu70 wrote: 05 Mar 2022, 21:44 I cannot ‘unpack’ the patch.
The only other time I seen that, it was a download error. Deleting the patch and downloading it again fixed the problem.
Stu70
Post by Stu70 »
Appears that I was attempting to extract into a named folder. By changing the destination to just the c drive it ran and now appears to work. But I have no drop down box for communication tool.
I’ve read one of your posts about running a device install - but quite honestly I have read soooo many posts I now dream of Vida and repackaged.ISO’s.
I’m going to try one more time to delete and reload by following your instructions- maybe tomorrow, now I think I’ve made a bit of headway…
Stu70
Post by Stu70 »
Sorry, me again…
dice setup :\3PP\Profucts\DiCE\
X in interface box - Vidamedia:\install…
Where do I go to type these addresses(?) in?
Thank you for your patience
