VIDA 2014D_Repack install on Windows 10, any version.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
LozinOz wrote: 28 Feb 2022, 21:14 ‘GetCommToolSettingsObject(…)DiagnosticsAllowed is not a function’ - I’m at a loss what to do now. I’ve rebooted PC tried more than once - sane message.
Which browser are you using?
If you are using Microsoft Edge install the IE TAB extension.
Active
Past
LozinOz
Year and Model: 2012 XC60 D5
Has thanked: 3 times
Post by LozinOz »
Thanks Rick
Yes was trying with Edge as saw supported with the IE Tab extension which I did install (or thought so - I will check) happy to use Chrome etc (which I’ll try) - would the browser cause that type of error?
Cheers
RickHaleParker
LozinOz wrote: 28 Feb 2022, 23:16 Yes was trying with Edge as saw supported with the IE Tab extension which I did install
Vida has a lot of dependencies. Including Internet explorer. IE TAB takes care of that dependency.
Try the IE hosting in the iso. VIDA:\Install\Utils\EnableIEHostingx64.reg . EnableIEHostingx86.reg if you have 32 bit version of windows.
Reboot and try again.
Active
Past
LozinOz
Post by LozinOz »
Thanks understand, I’ll try appropriate options & let you know - pretty sure I’m on x64 but have several PCs so best to check everything.
Appreciated
LozinOz
Post by LozinOz »
Hi Rick
That nudge did the trick - working fine now (I’d not correctly set up IE hosting I’m pretty sure - I redid that & retried - worked 👌
Thank-you so much, I knew I was close but without your help I’d still be scratching my head.
Cheers
Loz
Stu70
Year and Model: 2006 Sonic VR GT
Has thanked: 34 times
Been thanked: 26 times
Post by Stu70 »
I’m nearly in tears…
I cannot ‘unpack’ the patch.
I just get …
I have tried for seven days, bought another laptop , Recovered / restarted windows many times on my two machines. I am completely at a loss.
I delete the patch folders, I download again, I attempt to extract and …foiled again
On one machine I have Vida log in page but can’t enter any thing in ( which is what the patch is for) as I proceeded with all the install steps without fully completing step 4 ‘run the 2099 patch’.
I’m very sad - but a dab hand at restarting laptops and erasing everything.
RickHaleParker I need your guidance, I can follow step by steps but am a complete novice and not familiar with the ‘back streets’ of windows.
Am I even doing it right ?
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
Stu70
Post by Stu70 »
Deleted post - thought I had sorted.
RickHaleParker
Stu70 wrote: 05 Mar 2022, 21:44 I cannot ‘unpack’ the patch.
The only other time I seen that, it was a download error. Deleting the patch and downloading it again fixed the problem.
Active
Past
Stu70
Post by Stu70 »
Appears that I was attempting to extract into a named folder. By changing the destination to just the c drive it ran and now appears to work. But I have no drop down box for communication tool.
I’ve read one of your posts about running a device install - but quite honestly I have read soooo many posts I now dream of Vida and repackaged.ISO’s.
I’m going to try one more time to delete and reload by following your instructions- maybe tomorrow, now I think I’ve made a bit of headway…
Stu70
Post by Stu70 »
Sorry, me again…
dice setup :\3PP\Profucts\DiCE\
X in interface box - Vidamedia:\install…
Where do I go to type these addresses(?) in?
Thank you for your patience
