I'd like to replace my gas cap. It dawned on me that mine is not original. It's a locking cap, and I don't have the key. I'm a bit concerned that it could accidentally lock by itself.... or glove-box itself.
I've found this: https://www.ipdusa.com/products/4676/Fu ... 044-113515
Is this what my 96 850 would have had from Volvo, or is it a later Volvo cap that just works on my car? I'm a little gun shy of paying that much for a cap and not getting an original. I did that with my truck (although it wasn't this much $$$) and I got a later cap that "works" on my truck, but props the fuel door open slightly.
If it's not the original design, I'd rather just buy a non-locking aftermaket cap.
Gas cap replacement
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
Gas cap replacement
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1853 times
- Been thanked: 1714 times
FCP Euro also list that part number as suitable for most Volvo models from 240 onwards including the 96 850 models.
Strange this is I have found 2 different part numbers on Volvo dealer websites.
https://parts.volvovilla.com/p/Volvo_19 ... 75962.html
On this website is shows part #9475962 and fitting Volvos up to and including P80 models and first gen V50/S40 to 2004 but not P2 models. It is also cheaper than from your US websites!!
I also see this part number but the difference is it is RED in color # 9142541
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
This is NOT an original 850 cap. The 850 caps came with a little plastic loop so you could hang them on the fuel door while refilling.
The cap you listed surely works fine, though.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 24 times
This is a 3$ item at a salvage yard there are zillions of them. If you can hang on a bit I can locate a few easily. I have 3 or so of my own. Save the 40 $ difference just get a new gasket, OEM Volvo or maybe the HD one from IPD. Yes, I wouldn't go aftermarket on this item myself.
454cid
There's no such thing as a $3 item at my closest yard. They told me several years ago that $5 was the bottom limit. Last time I was there they wanted to charge me something like $25 for a broken part that I was going to have to disassemble along with my current part and build one good one. I ended up getting them down to $10.rguzz wrote: ↑01 Mar 2022, 16:48 This is a 3$ item at a salvage yard there are zillions of them. If you can hang on a bit I can locate a few easily. I have 3 or so of my own. Save the 40 $ difference just get a new gasket, OEM Volvo or maybe the HD one from IPD. Yes, I wouldn't go aftermarket on this item myself.
I can wait, if you can find a good one or two on your next trip to the salvage yard.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1507 times
- Been thanked: 3823 times
I think I have a spare oem cap somewhere. Pm an address and I can send
Can you guys tell me if a 1998 or 1999 gas cap will work in any P80?
Need to know for this replacement.
454cid
I've been meaning to get back to this...
Here's a picture of the gas cap installed that Abscate sent. First I scrubbed it up. Then I swapped the gasket from the locking cap on, and used a bit of silicone grease on it. I also sprayed some vinyl protectant on it that I normally reserve for my engine compartments, just to make it look a little better.
Thanks Abscate!
Thanks Abscate!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Man, if I had cleaned it up I would’ve tripled the price.
