Source for 1999 s70 awd rack hard lines
deano1
Year and Model: 2001 s60 1999 awd
Has thanked: 13 times
Been thanked: 16 times
Post by deano1 »
My title say it all
My Volvo source says they're no longer available?,, I bumped one now it's leaking.
anybody know a source?
special hard pipe flare end... not really like brake line flare I've ever seen :o
Cheers
Has thanked: 1511 times
Been thanked: 3827 times
I think that’s the return hose 1282852
Volvo is still available, about $120 last fall
FCP euro has them
deano1
Post by deano1 »
Hey Captain
These lines I speak of are smaller,, 1/4" maybe and run parallel to the rack. #21-#22 below. #21 is the actual one i have that leaking :( . I was prepping it for a coat of rust paint to maybe extend it's service life when i noticed the leak.
Dwg I posted is of a S70 rack but not for 1999 awd, Ours slightly different, example- No engine pad mount and line #22 runs to behind to rear of the rack.
Lines are still available for this one and line #21 is very similar to what I need but I'm just not sure they have the same flare type.
Ah, the transfer lines. They shuttle fluid from side to side of the rack as you turn
Those are indeed NLA in Volvoworld last I checked they didn’t even show as a part number.
They aren’t horrible to harvest from a junkyard if you can find the right model. AWD might be tough
deano1
Post by deano1 »
I know what you're saying,,, I tried soldering them tonight!
Hahaha! What a joke! I may as well used bubble gum eh. But no choice really.
I'll try it this way until i can find a better solution.
Seriously I think a bubble flare would work in place of that O ring set up just need to locate the flare nuts with proper thread.
Then I can use copper line :wink:
If you have a pinhole on the straight pipe you can swage in a piece of replacement or do a tight hose bridge with double oetiker clamps
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
That's a straight thread, and not tapered, correct? It looks like the same setup as the oil cooler lines from my truck. It's got a name, and there are dies for "flaring" those, but I don't know the proper terms.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
deano1
Post by deano1 »
Would love to just splice a piece in but it's was leaking right at the turn before entering the rack.
I do believe it is straight thread,, technical name,,12mm x 1mm or so me thinks as far as i can gather from McMaster Carr..
Could also be just a straight metric thread I don't know for sure because I don't have a die in my set for that size although 1/2"-20 is very close... still digging :wink:
Let me know if you figure it out before me.
cheers
I’m back at my car on Monday. Could look in the Stash and tell you what I have and or measure threads
deano1
Post by deano1 »
Well that would be much appreciated
cheers
