Mirror Glass Fell Off, Glue Type?
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Sveedy wrote: 14 Mar 2022, 08:48 Well personally, if my mirror fell off and didn't break, then the first thing I'd do is go buy a lottery ticket.
Then try taking it to your local auto glass shop and ask them about it. Good to have a relationship with one of those shops anyway for obvious reasons. They probably have the proper glue. I'm guessing it's an epoxy, as opposed to the butyl type. If your lucky, they won't charge you anything, thinking about your potential future business ( windshield ).
Sounds like a good idea, thanks.
I have two tests set up now with high quality silicone.
One is on plastic like the backing and at room temperature, the other is in the fridge at about 40 degrees F.
They both cured within 12 hours.
I didnt test the strength of the plastic test yet because i want that to go the full 24 hours.
If the plastic test goes well i might just go with that and forget about it for now.
MrAl
Post by MrAl »
June wrote: 14 Mar 2022, 18:19 Go to junkyard and pop the mirror with plastic back still attached and install it in your housing. That plastic backplate pops off the electric motors. So when the glue fails and the mirror glass is gone, get a used one. I had the mirror re bonded by a glass shop and it was gone by the time I made it home. So when the second did the same thing I went straight for a new replacement. I broke the mirror on a 2012 Prius and the replacement was $1,500. I drove it only once... June
Yes that's an option too thanks.
We have far and few junk yards around here anymore though.
Long time back we had two very large ones in South Plainfield. They both closed up.
We also had one about a mile from here. Closed up.
Id have to look around for another one. We might have one left up the mountain but not sure how big it is. I'll have to check and see if it is still there.
I think they have been selling out because of real estate prices.
So you are saying that the plastic part pops out? So i can take it into the house and examine it and test it with my glue or whatrever. Is that right?
How hard is it to pop out?
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
MrAl wrote: 14 Mar 2022, 06:17 Ok just went out there to check it out.
Yes there is a smooth plastic plate insdie filling up the whole entrance of the mirror cup.
So yes the glass separated from the plastic.
The plastice may have warped slightly so the glass probably wont fit flat aganist the plastic so i guess a lot of glue filler will be needed. Well, a little more than usual i guess but no big deal.
Now does silicone stick well to plastic, that's the question. It has to stay on or else it could drop of on the road somewhere i might not even notice it right away. Dont want to have to buy a whole new mirror :-)
You know what else is strange, there is no glue on the mirror or the plastic backing.
I think you're over thinking this. Just get some spring clamps, silicone glue, and clean your surfaces well and stick it together. The clamps will bend the plastic to the glass.
You might put the plastic in a sunny window just to heat it up a bit. Soap and water to clean followed up with alcohol.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
MrAl
Post by MrAl »
454cid wrote: 15 Mar 2022, 01:48
Well i'd love to do that but how do you get the plastic backing plate out from the mirror shell?
Only the glass came off not the backing plate.
Has thanked: 1609 times
Been thanked: 4064 times
You’ve got Harry’s in Hazleton nearby, and Alex and Sean here both frequent junkyards and can scavenge easy parts for you. Kick them some bucks to keep the Kharmic scales level
I’ve got a 99 scavenge in my driveway too, what parts are needed?
454cid
Post by 454cid »
MrAl wrote: 15 Mar 2022, 03:39 Well i'd love to do that but how do you get the plastic backing plate out from the mirror shell?
The video that was posted earlier will show you. They just snap off.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
MrAl
Post by MrAl »
abscate wrote: 15 Mar 2022, 04:55 You’ve got Harry’s in Hazleton nearby, and Alex and Sean here both frequent junkyards and can scavenge easy parts for you. Kick them some bucks to keep the Kharmic scales level
Hi,
That sounds good, but i dont konw all the members by their first names only their screen names usually.
You'd have to list their screen names.
Thanks.
MrAl
Post by MrAl »
454cid wrote: 15 Mar 2022, 11:13
Hi,
I checked it out they just show the guy using a screwdriver behind the plastic but not sure what is being pryed.
I worry about breaking the plastic which must be old now if i dont do it just right.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
My Service Advisor popped the old ones off and the new ones on right on the Service drive. It took him all of a minute to do. The plastic just popped off, then the new one went on with a snapping sound. He's not a mechanic, so it must be easy. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
MrAl
Post by MrAl »
June wrote: 15 Mar 2022, 14:27 My Service Advisor popped the old ones off and the new ones on right on the Service drive. It took him all of a minute to do. The plastic just popped off, then the new one went on with a snapping sound. He's not a mechanic, so it must be easy. June
Hi June,
I included a pic of the plastic part both sides.
Thanks for the info i got it off now.
The pic hows the side where the glue goes and it has a bunch of metal paths on it as you can see. That means it is heated and that was a bit of a surprise to me i did not know they were heated. The two indents show there the connetion posts are mounted.
The back of the plastic just looks like it has some catch posts that go into the mirror when it is reinstalled. The two terminals are clearly visible.
The circuit traces measure 8.7 Ohms.
