Vida CEM swapping
ZRimaZ
Year and Model: XC60 MY2016 3.0 T6
Has thanked: 23 times
Been thanked: 13 times
Post by ZRimaZ »
gnalan wrote: 15 Mar 2022, 13:19 Has anyone tried this on the CEM-B to read the eeprom to get the pin from the .bin file?
This one https://www.usbjtag.com/jtagnt/ulinknt.php is working very well without desoldering of flash chip
Have a nice day,
ZRimaZ
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
ZRimaZ wrote: 15 Mar 2022, 13:48 This one https://www.usbjtag.com/jtagnt/ulinknt.php is working very well without desoldering of flash chip
I haven't taken my CEM apart, or any CEM, so I don't know exactly what's inside. How are the connections made? For $65 that doesn't seem to be a bad price to get the CEM pin. Thanks for the info.
ZRimaZ
Post by ZRimaZ »
gnalan wrote: 15 Mar 2022, 13:57
It is very easy - all info you can find on their forum https://www.usbjtag.com/phpbb3/viewtopi ... =22&t=9339
Have a nice day,
ZRimaZ
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
vtl wrote: 09 Mar 2022, 14:46 It does not crack mine (difficult third byte).
What is the part number?
I got a bench 31314468 that is being a PITA on the third byte.
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 21 Mar 2022, 13:52
Part Number: 30728542
Don't remember the original P/N, my CEM was reflashed many times.
RickHaleParker
vtl wrote: 21 Mar 2022, 14:08 Don't remember the original P/N, my CEM was reflashed many times.
I cannot draw any conclusions from that, it is P/N Heinz 57. :lol:
Active
Past
RickHaleParker
vtl wrote: 28 Feb 2022, 10:31 @sirloins any tricks in wiring the 719? I see messages from ID 0x7de up powering it up, however it does not react to the read p/n requests.
Did you ever git the 719 to fired up? I got one of Sirloin's 719 on my bench.
30-supply to E20 - E23.
Power Ground A28.
Signal Ground A14.
HS-H B11
HS-L B12
LS-L B15
LS-H B16
VTL:Main
CPU Maximum Frequency: 600000000
CPU Frequency: 180000000
Execution Rate: 180 cycles/us
PIN bytes to measure: 3
CAN low-speed init done.
CAN high-speed init done.
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=50 88 00 00 00 00 00 00
Part Number: 0
Unknown CEM part number 0. Don't know what to do.
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
Faster-attempt
PIN bytes to measure: 4
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
Can't find part number on CAN-LS, trying CAN-HS at 500 Kbps
CAN_HS ---> ID=000ffffe data=cb 50 b9 f0 00 00 00 00
Resetting all ECUs.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 22 Mar 2022, 08:50
Power Ground A28.
Signal Ground A14.
HS-H B11
HS-L B12
LS-L B15
LS-H B16
Yes.
+12 to Front-1:21
GND to Cockpit-1:28
CAN pins are correct.
vtl
Post by vtl »
Speaking about 719/720 and sirloin's new code. I tried to power it up after sitting idle for a couple of weeks:
Code: Select all
$ git remote -v
origin	https://github.com/cmolson/volvo-cem-cracker.git (fetch)
origin	https://github.com/cmolson/volvo-cem-cracker.git (push)
$ git status --short
It did all 3 permitted iteration on pin[2] with a different outcome on every run:
Code: Select all
best candidates ordered by latency:
0: 09 lat = 2614209, prev: -100.0000%, best: -0.0000%
1: 43 lat = 2612765, prev: -0.0552%, best: -0.0552%
0: 90 lat = 7786689, prev: -100.0000%, best: -0.0000%
1: 47 lat = 7785527, prev: -0.0149%, best: -0.0149%
0: 64 lat = 15572173, prev: -100.0000%, best: -0.0000%
1: 22 lat = 15486240, prev: -0.5518%, best: -0.5518%
As a consequence, it failed to crack:
Code: Select all
Candidate PIN 13 49 64 15 -- -- : brute forcing bytes 4 to 5 (2 bytes), will take up to 20 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 165.84 seconds
done
Weeks ago, when I tried to crack it, it was able to do so. As stated previously in the thread, the master branch runs for so long for a good reason. It is possible to cut corners here and there, it will crack your CEM, but will fail others.
RickHaleParker
Power Ground A28.
Signal Ground A14.
HS-H B11
HS-L B12
LS-L B15
LS-H B16
Never mind I got it. For some reason it does not work if you connect E20
This works:
30-supply to E21 - E23 E20 - E23.
Power Ground A28.
Signal Ground A14.
HS-H B11
HS-L B12
LS-L B15
LS-H B16
Active
Past
