Volvo 850 10v to 20v Conversion.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Pistons are never a problem on these cars.
Not on a 10v ...not on a 20v cars.
How much oil consumption per 1.000km you have?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
My '96 was 4.3 stock, not 4.4. I switched it to 4.4 when I replaced the ECU with a flashable one.
1999 V70 GLT
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Sveedy wrote: 05 Apr 2022, 09:55 My '96 was 4.3 stock, not 4.4. I switched it to 4.4 when I replaced the ECU with a flashable one.
The NA's were M4.4 starting in '96. HPT Turbos went M4.4 in '98 (LPTs did so in '97, but the ECU internals are different from the '98 MY ones(at least in the US))
misha
Post by misha »
850 turbo are all m4.3.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
2ndGenVolvos
Year and Model: 1996 850
Post by 2ndGenVolvos »
scot850 wrote: 05 Apr 2022, 09:38 What mileage is on the current engine? If is is fairly low mileage it may be the cheapest to have the head rebuilt if you and your Dad can do the strip and rebuild. You will need a machine shop to plain the head and have the head rebuilt with new seals. But you could probably do that for around $1000-1200 or less as it is a 10V motor.
Yes you can buy a $900 car with a motor in it but how good is that motor?
You can compression test your existing motor to see what the compressions are like. Your Dad will know how to do that.
Current engine has 231,xxx kms. The engine in the $900 car says 280,000 but who knows if thats accurate as the gear could have broken, I'd have to check the ECU.
I'll have to pull up the engine maps and see what sensors, harnesses, etc. I would need to convert my car to a 20v.
Because if the engine in the 280k car is still in good condition, then it could be worth it to just drop it in. Or at the very least use it for parts.
Ideally, I'd like to have 20v for that little extra oomf. But we'll see where we land once I have all the information I need to make a decision.
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
2ndGenVolvos wrote: 05 Apr 2022, 12:17 Ideally, I'd like to have 20v for that little extra oomf. But we'll see where we land once I have all the information I need to make a decision.
My 20V NA engine is not a hot rod. It's fine for daily driving, but it's not a rocket. I think my engine is supposed to be 168hp. What's the 10valve rated?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
misha
Post by misha »
At 280K ...valve stem seals could also be a problem at that 20v engine.
Weak point on these cars.
You don't check ecu for a mileage...you check instrument cluster...since the mileage is stored in the cluster module.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
454cid wrote: 05 Apr 2022, 12:46
10v...if it is a 2.5 have around 104-106kw.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
2ndGenVolvos
10v NA is rated at 142hp. So not massive gains but just a nice little extra something-something for driving backroads or up in Muskoka.
2ndGenVolvos
misha wrote: 05 Apr 2022, 09:43 Pistons are never a problem on these cars.
No idea. Bought the car, got it home. Big blue clouds started billowing out when we pulled into the driveway. Prick that sold me the car stopped answering my texts and calls too.
