Vida CEM swapping
ZRimaZ
Year and Model: XC60 MY2016 3.0 T6
Has thanked: 23 times
Been thanked: 13 times
Re: Vida CEM swapping
Post by ZRimaZ »
IO terminal knows where PIN code is located for all P1, P3 and for P2 CEM-L and CEM-H. CEM-B it also can read/write via OBD, but for this you need to modify flash, at addresses 0x4000 or 0x6000 - replace existing PIN with FF.
It can't crack PIN, but if you have already PIN or you have flash read by other means, it can extract it from file
Have a nice day,
ZRimaZ
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
ZRimaZ wrote: 09 Apr 2022, 08:40 IO terminal knows where PIN code is located for all P1, P3 and for P2 CEM-L and CEM-H. CEM it also can read/write via OBD, but for this you need to modify flash, at adresses 0x4000 or 0x6000 - replace ecisting PIN with FF.
Well, yes, exactly what I thought.
charlie13
Year and Model: 2009 XC70
Been thanked: 18 times
Post by charlie13 »
vtl wrote: 09 Apr 2022, 08:34
urosm wrote: 09 Apr 2022, 01:23 IO cannot get the PIN from MC68376, unfortunately.
But for P2 facelift working like charm!
What do you mean exactly? Does I/O Terminal crack pin code now? Or it knows where to look for the pin in the flash dump?
I/0 has it solved the other way around, you need to desolder flash and load the content with changed pin. Patch Button 28F400B5 Flash File.
cem B.jpg (278.38 KiB) Viewed 1691 times
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
charlie13 wrote: 09 Apr 2022, 11:32 I/0 has it solved the other way around, you need to desolder flash and load the content with changed pin. Patch Button 28F400B5 Flash File.
What's the chance of bricking the CEM-B doing it this way?
vtl
Post by vtl »
gnalan wrote: 09 Apr 2022, 11:39 What's the chance of bricking the CEM-B doing it this way?
A rule of thumb is to use a fresh flash chip (and tin-lead allow).
Also for older CEMs I think you still can read/write flash unsoldered with BDM programmer.
charlie13
Post by charlie13 »
Read Intel 28F400 memory and send me I can give you the pin you read. You will do path and when the pin input function is added, as in the other modules, you will enter your own pin. This will allow you to embed car conf. I/0 software and using cem changes.
In fact, when you read the desoldered flash, you will also save the changes you want to make
ZRimaZ
Post by ZRimaZ »
IO terminal has no function to read/enter PIN foe CEM-B. As I wrote before, the flash of 29f400 has to be modified/patched either with io terminal or manually. The "patch" is simple replacing of original pin with FF. The pin is located at address 0x4000 or 0x6000, depending on cem version. To patch 28f400 you have to read&write it either by resoldering it or with bdm programmer without resoldering
Have a nice day,
ZRimaZ
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
ZRimaZ wrote: 09 Apr 2022, 12:45 The "patch" is simple replacing of original pin with FF. The pin is located at address 0x4000 or 0x6000, depending on cem version. To patch 28f400 you have to read&write it either by resoldering it or with bdm programmer without resoldering
Is there a checksum in in the 28f400? If so. where is it located, what type of checksum and for what block of data.
ZRimaZ
Post by ZRimaZ »
As far I know, there is only checksum for config block, not for whole flash
Have a nice day,
ZRimaZ
charlie13
Post by charlie13 »
EDIT Be careful. See two posts down. Matthew /EDIT
Programs for CEM B and P1 SID803. There may be a problem with the antivirus. There is no virus in the files
Volvo ECU-CEM Sync Tools.7z
(20.92 MiB) Downloaded 769 times
