IO terminal knows where PIN code is located for all P1, P3 and for P2 CEM-L and CEM-H. CEM-B it also can read/write via OBD, but for this you need to modify flash, at addresses 0x4000 or 0x6000 - replace existing PIN with FF.
It can't crack PIN, but if you have already PIN or you have flash read by other means, it can extract it from file
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Well, yes, exactly what I thought.ZRimaZ wrote: ↑09 Apr 2022, 08:40 IO terminal knows where PIN code is located for all P1, P3 and for P2 CEM-L and CEM-H. CEM it also can read/write via OBD, but for this you need to modify flash, at adresses 0x4000 or 0x6000 - replace ecisting PIN with FF.
- charlie13
- Year and Model: 2009 XC70
- Been thanked: 18 times
I/0 has it solved the other way around, you need to desolder flash and load the content with changed pin. Patch Button 28F400B5 Flash File.
- cem B.jpg (278.38 KiB) Viewed 1677 times
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
What's the chance of bricking the CEM-B doing it this way?
- charlie13
Read Intel 28F400 memory and send me I can give you the pin you read. You will do path and when the pin input function is added, as in the other modules, you will enter your own pin. This will allow you to embed car conf. I/0 software and using cem changes.
In fact, when you read the desoldered flash, you will also save the changes you want to make
ZRimaZ
- Year and Model: XC60 MY2016 3.0 T6
- Has thanked: 23 times
- Been thanked: 13 times
IO terminal has no function to read/enter PIN foe CEM-B. As I wrote before, the flash of 29f400 has to be modified/patched either with io terminal or manually. The "patch" is simple replacing of original pin with FF. The pin is located at address 0x4000 or 0x6000, depending on cem version. To patch 28f400 you have to read&write it either by resoldering it or with bdm programmer without resoldering
Have a nice day,
ZRimaZ
ZRimaZ
- RickHaleParker
- Been thanked: 958 times
Is there a checksum in in the 28f400? If so. where is it located, what type of checksum and for what block of data.
- charlie13
EDIT Be careful. See two posts down. Matthew /EDIT
Programs for CEM B and P1 SID803. There may be a problem with the antivirus. There is no virus in the files
- Volvo ECU-CEM Sync Tools.7z
- (20.92 MiB) Downloaded 769 times
- 6431 Views
Last post by RickHaleParker
- 8699 Views
Last post by forumoto
