When to replace struts…?
91Bravo
Year and Model: 2011
Post by 91Bravo »
Hello! I recently purchased a ‘11 V8 Executive from Texas. Noticed it had an obvious clunking sound coming from what seemed like the driver side. Took it to the dealer, they came back with an astronomical quote for tie rods and control arms bushings (as well as timing and valve cover gaskets…that was $8500) So I purchased inner and outer tie rods and control arms from IPD and had them installed at an indie. The clunking went away for the most part but it’s not completely gone. Also the ride just seems floaty. So my question is when should struts be replaced? As far I can tell they’re original and I’m coming up on 158K miles. Any advice or recommendations will be greatly appreciated.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
I'm waiting for that perfect V8 myself but have test driven 2, one with the 3.2 and the other 2.5. Strange suspension setup as the SUV feel like the steering is below the front seat. Both were soft so I would recommend Bilstein or Koni if available.
Another option is to put on some sway bars beginning with the rear. Volvos are all prone to under-steering and the with bigger motor it will be more so than the 2.5 or 3.2. The sway bar will also act to smooth the small modulations in the road besides the up and down motions of the wheel and make the SUV feel more hunker down. When one side of the wheel goes up and down the other side pulls it back. Not meant to replace worn shocks but it does firm the suspension up for a more stable road feel.
MoVolvos
Post by MoVolvos »
A set of subframe bushing inserts are a must if available beside replacing the front control arm forward and rearward bushings.
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Post by chitownV »
91Bravo wrote: 10 Apr 2022, 19:22 Hello! I recently purchased a ‘11 V8 Executive from Texas. Noticed it had an obvious clunking sound coming from what seemed like the driver side. Took it to the dealer, they came back with an astronomical quote for tie rods and control arms bushings (as well as timing and valve cover gaskets…that was $8500) So I purchased inner and outer tie rods and control arms from IPD and had them installed at an indie. The clunking went away for the most part but it’s not completely gone. Also the ride just seems floaty. So my question is when should struts be replaced? As far I can tell they’re original and I’m coming up on 158K miles. Any advice or recommendations will be greatly appreciated.
With that mileage and the weight of the V8, it definitely sounds like you will need new struts and associated hardware. I like Bilsteins as they do very well on the XC90. Avoid Sachs as both V8 and 3.2 owners say they are too soft.
Here is a write-up of parts and reviews for the front end. Since you have already started with the tie-rods, the next things to do are the control arm bushings, the ball joints, and the struts (plus mounting hardware). Clunking can come from any of these and with 158k miles, it is recommended to change them all. Getting the foundation and geometry of the front suspension replaced first should always be the first step. I have performance sway bars, but that would be second or third on the list of things to do, and there is no overlap in labor with the front suspension parts. Doing sway bars is not an easy job in the XC90.
Check here for the front-end parts and review: https://www.swedespeed.com/threads/chit ... ts.590829/
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
91Bravo
Post by 91Bravo »
Great info, thank you!
