Engine mounts
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Engine mounts
Post by Nevada1906 »
The last parts I need to physically install my engine and transaxle in my 850 are the mounts. FCP and IPD both sell mounts, but of varying quality and WIDELY varying price. Which manufacturers are okay, and which ones do I want to avoid?
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
Has thanked: 1839 times
Been thanked: 1709 times
Hutchison are now thought to be the OE supplier. I have used their parts in the past with no issues.
I have seen others use other brands other then OE but I tend to like to do the job once! I used a Rein crank pulley mount on a 96 850 NA and it lasted about 2 years and separated.
quietlymknnoise67
Year and Model: 2003 C70
Post by quietlymknnoise67 »
OEM is best
Nevada1906
quietlymknnoise67 wrote: 21 Apr 2022, 15:10 OEM is best
OEM is also most expensive.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
It is just my opinion, not proven through true Scientific Method, that the budget front and back mounts are solid rubber, not fluid filled like from the factory, leading to lots of extra noise and vibration. Like Neil, I used an inexpensive right mount once, and it sagged well before its time. That one isn't hateful to change, but the other two are., so I would be tempted to spend the money on the buried mounts, and take a chance on the right side and top torque units.
Has thanked: 292 times
Been thanked: 765 times
viewtopic.php?t=99882
Hurry. But make an offer :wink: .
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
I bet on OEM parts. Job made once. Price paid once. I don't know other sellers quality. MVS advices are my guide !
foggydogg
Post by foggydogg »
erikv11 wrote: 21 Apr 2022, 20:02 viewtopic.php?t=99882
And as mentioned elsewhere here, there is a chassis break on the left (front) mount, so some research would be needed if this option is explored.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Thanks for linking my sale thread! I'm moving in a few weeks, and if they work for OP, I'll def consider a pretty good discount. I just want them gone soon.
The thread has a post with the potential fitment details for the right mount.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Also keep in mind, you can easily (if you have the parts) covert from one chassis mount to the other by unbolting the mount-mating piece from the block, and switching it over to the other block. I've done that before you can easily do it with the engine in the car, even simpler for OP who has engine out of the vehicle.
OP is installing an RN engine, likely that works with the later-chassis-P80 mount that FlyingVolvo is selling.
'06 S60 R, 197k
