850 Corner light specification help, please
markone
Year and Model: 2007 V70
Has thanked: 21 times
Been thanked: 14 times
Post by markone »
Hi folks,
Somewhere in upstate New York, there is a clear lens lying roadside from the driver's corner light on the '97 850 base.
Using my VIN, FCP says I need Volvo part number 6808834. IPD says the OEM number is 6817769. Carparts says the OEM number is 68177690. The part seems to be listed variously as a corner light, a combined light, or a turn signal light.
Does anyone have advice on how to determine which I might need, and if I should get additional items- spring clip, receptacle, etc?
Thank you!
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
I think, the difference is between single and dual bulb headlights. Each apparently uses a difference corner light... at least that's what I am thinking given what I've seen when looking at lights.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1853 times
Been thanked: 1714 times
This link may help. This shows 2 different types hence the different part numbers. What may help is the picture of what is behind the lamp to help identify which you have:
https://parts.volvocars.ca/a/Volvo_1997 ... 64936.html
Has thanked: 1507 times
Been thanked: 3824 times
I’ve got a couple of V70 lights, will those fit or does the sexy v70 curves ignore Mr Boxy 850?
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
V70 ones are different.
Early 850 ones will also not fit('92-'94).
'95-'97 will.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
markone
Post by markone »
Thanks, gentlemen. Car and I are separated by 350 miles. With your help I am getting closer to a solution. Car has two-lamp headlight and the roughly 5” tall unit. Choices are narrowing!
rguzz
Year and Model: 1996 850 turbo
Been thanked: 24 times
Post by rguzz »
I can look in local yard there are 850's there. Often these corners are missing or beat up. I expect to be there early next week, doubt I'll be charged more than a few bucks if I am lucky enough to find a good one. I can make sure it's complete with spring, etc. though yours is in place I'm sure. I think the fit of the e-bay versions is fine IIRC, however.
Isn’t she driving by Erie VoVo between North and SU?
Has thanked: 293 times
Been thanked: 765 times
A key part to look at from a junkyard, 850 corner light (aside from the spring) is the mounting tab, these are usually broken.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
markone
Post by markone »
I will check if she passes Erie VoVo, and those junkyard pro tips are much appreciated! I went ahead and ordered a new part from Eeuroparts. I have not been able to source the attaching spring, so I will have to be careful in the swap-out. Thanks again for your help.
