- Has thanked: 1502 times
- Been thanked: 3817 times
Tough crowd here. Big birds should be easy to get but that kestrel was a flash by at 60 mph
- Has thanked: 927 times
- Been thanked: 1000 times
Ok. You get a pass.
A passerine, Shirley
Dang, now I learned something new.
A passerine is any bird of the order Passeriformes, which includes more than half of all bird species.
Why do geese fly in lines?
It’s a No Passerine Zone.
Try the Veal!
Tip your Waitress!
Try the Veal!
Tip your Waitress!
- Has thanked: 1846 times
- Been thanked: 1710 times
Well I remembered why I hate this stupid V70R so much!!
Removed the rear LH door panel to get the door actuator out. Every gosh darned (I'm being polite for a Scotsman!!) door clip mount has fallen off the door panel!! No not one, not two but all fersshluggener 6 off of them, as well as the center section has also come apart from the surround. I have had to repair the stupid panels on several P80's due to Volvo stupidity using bio-degradable glue.
Man I hate this car! Maybe one day I will get a straight forward repair that does not require repairing the rest of the car around it!
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
"Patience is a Virtue."scot850 wrote: ↑24 Apr 2022, 15:26 Well I remembered why I hate this stupid V70R so much!!
Man I hate this car! Maybe one day I will get a straight forward repair that does not require repairing the rest of the car around it!![]()
Steve Cauthen, after winning the Kentucky derby in 1978 at age 18.
- Has thanked: 304 times
- Been thanked: 517 times
P80 door panels suck. They have conditioned me to be nervous removing any door panel on any vehicle. I forget that my BMW door panels are so much stronger than the Volvo ones
Yup I agree. I used to have patience working on cars, in fact I considered it therapy from a stressful day. This car however managed to remove the 'fun' part of that. I don't mind working on other's cars, only that one!!
I do however now expect the other rear door to be the same as I don't believe I repaired that one. A 'professional' repaired the LH front door and mad a a mess of it by using a small clamp which has left an 'impression' on it. It is also a poorly attached center section with gaps in it. I did the RH front one at it is way better. In between I did all 4 of the panels on my 2000 V70 base. Overall it is tiresome fixing stuff you shouldn't be having to. The hard part will be all 7 of the mounts have fallen off so I will have to find a way to get them all in the correct spots or the panel will not re-fit. May have to do one at a time starting at one corner, then the opposite side and then hope if they align then the rest will too.
Looks like a multi-day project for a 2 hour job!
But one BMW mount will be$ 229.99, and $429.99 if it’s an MI forget that my BMW door panels are so much stronger than the Volvo ones
