I think that may be it. If the range of PINs is known to be limited to BCD on the P3, then you only have so many possible PINs, there will be theoretical SEED/KEY pairs for which there is no possible BCD match. I'm not quite sure why you need to iterate through more than the set of possible PINs, but I didn't go far down the road of coding the minimum set of BCD possibilities, as the SPA appears to use the full range of HEX values for PINs on ECUs, so I abandoned the BCD iterations. A lookup table could be generated but that may not be efficient.vtl wrote: 26 Apr 2022, 09:41 While pin range of 100^4 is 6 times more than 256^3, the right key will be hit with 1 in 100^4/8=12500000 probability for BCD, while for HEX it is 1 in 256^3. BCD is 1:12.5M, HEX is 1:16.7M.
Vida CEM swapping
Power6
- Year and Model: 2019 S60
- Been thanked: 12 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Iterating over 3 PIN bytes in HEX: SEED produces unique KEY for PIN. A chance of hitting a match is 1:16.7M
Iterating over 4 PIN bytes in BCD: SEED produces non-unique KEY for PIN. There's a chance of producing duplicate KEY, the probability varies from 1:1 to 1:23. See the table above, this is programmatically generated. On weighted average, the chance is about 1:8.
While going over all 100^4 possible PIN BCD values, there's a 1:8 chance of hitting the right KEY. This gives a PIN match probability of 1 to 100^4 * 1:8 = 1:12.5M. This probability is actually not constant, as the weighted average of 1:8 is really a 1:1 to 1:23 spread.
Power6
What makes a PIN more probable than another... For 1:12.5M you'd have to crack maybe thousands of CEMs to say that. For a single CEM, I can code a crack that has 100% probability of the first PIN match. You've probably cracked more than a few though i imagine.vtl wrote: 26 Apr 2022, 10:04 While going over all 100^4 possible PIN BCD values, there's a 1:8 chance of hitting the right KEY. This gives a PIN match probability of 1 to 100^4 * 1:8 = 1:12.5M. This probability is actually not constant, as the weighted average of 1:8 is really a 1:1 to 1:23 spread.
Not being argumentative, if there is some logic to guessing a more likely PIN that could be applied, I wanted to attempt to understand that!
vtl
That's the beauty of math: it explains things you yet have to seePower6 wrote: 26 Apr 2022, 10:12 For 1:12.5M you'd have to crack maybe thousands of CEMs to say that.
Power6
That's something like what I said to Rick when he didn't buy the "3-bytes of PIN" theory. But we are in agreement after testing it out.
I don't see anything that proves anything, not that you are required to share it! I guess if you start with 100 million PINs, it's true some are more likely than others because you are starting with a ton of duplicates. Rule out a PIN, no reason to consider the duplicates. However you rule those duplicates out works I suppose.
Don't have that problem in HEX, start with 17 million, all unique possibilities. Still a lot though for cracking in the car for SPA with security features though. But way less than 5 bytes of entropy. Will keep working on that.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
vtl wrote: 26 Apr 2022, 10:23 That's the beauty of math: it explains things you yet have to seeIf ever.
Code: Select all
seed = 0xBDFA1A;
pin = 0xFFFFC8E6CD;
real_key = 0x4C0E2B;
v0 = (real_key & 0xFFFFFF);
v1 = (((pin & 0xFF) << 56) | ((pin & 0xFF00) << 40) | ((pin & 0xFF0000) << 24) | ((pin & 0xFF000000) << 8) | ((pin & 0xFF00000000) >> 8) | ((seed & 0xFF) << 16) | (seed & 0xFF00) | ((seed & 0xFF0000) >> 16));
v2 = 0xC541A9;
for x in range(0,64):
v3 = ((v2 & 1) ^ ((v1 >> x) & 1));
v4 = (v2 >> 1);
if v3==1:
v2 = (v4 ^ 0x909028);
else:
v2 = v4;
key = (((v2 & 0xF0000) >> 16) | ((v2 & 0xF) << 4) | ((v2 & 0xF00000) >> 12) | (v2 & 0xF000) | ((v2 & 0xF0) << 12) | ((v2 & 0xF00) << 12));
print("Computed key: 0x%X" % key);
print("Real key: 0x%X" % v0);
Next is a rewrite of my Algo in C++, cleaned up, without all the bit shifting that is still shown here.
- gnalan
It's not bad, it just makes the code look messy.
- gnalan
I optimized the for loop by looking at the Algo that's everywhere, breaking it down to its separate parts and pieces, and rewriting it. I believe we're on the same page, but doing one step differently which is why your value 'm' takes up an extra nibble.vtl wrote: 26 Apr 2022, 10:23 That's the beauty of math: it explains things you yet have to seeIf ever.
Also '++i' doesn't need to make a copy of 'i' first like 'i++' does.
Code: Select all
Yours...
unsigned int n = 0xc541a9, m = 0x1212050;
for (i = 0; i < 64; i++, n >>= 1, k >>= 1)
if ((n ^ k) & 0x1)
n ^= m;
Mine...
unsigned int n = 0xc541a9, m = 0x909028;
for(i = 0; i < 64; ++i)
if ((n & 1) ^ ((k >> i) & 1))
n = ((n >> 1) ^ m);
else
n >>= 1;
alevol
- Year and Model: 2005 S60
- Has thanked: 6 times
- Been thanked: 3 times
How do you get ~860 pin/sec? I am getting stable 440 pins/sec using VTL's the most recent build.
I could also not compile VTL's seed-gen.c utility. I was trying to compile with devc++ and with VScode as well. It could not find dependencies.
Thanks
edit: found hash collision in about 2h. Nice. And it was slow cem@440pins/sec
Thanks
- 10079 Views
Last post by RickHaleParker
- 10596 Views
- 27 Replies
- 32399 Views
Last post by cn90
- 10 Replies
- 12513 Views
Last post by jonesg
- 7417 Views
