Is there a link to a video for changing the timing belt on a 2006 V 70?
I have replaced the timing belt on my 96 850 and watched videos on changing the belt on v70's up to 2005.
Thanks
Owner of, 87 240, 96 850, 97 850 and 2006 V70
2006 v70 timing belt replacement instructions
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
last belt i changed I just lined it up and locked the cams, switched the belt , rotated the engine a couple of times by hand to confirm and it was done. If it was timed good at the beginning it will be the same after.
As long as you lock both the cams and the hubs relative to the cams this will work
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
If all you’re doing is replacing the belt, and not removing sprockets or hubs, then you don’t have to lock anything. Just make sure all three timing marks are on their marks before removing the old belt and after the new belt is installed. I like to make my own reference marks with a Sharpie (especially on the crank sprocket) before I remove the old belt.abscate wrote: 25 May 2022, 05:59 As long as you lock both the cams and the hubs relative to the cams this will work
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I did mine last year on my '03 XC. Make sure you change the water pump and idler and pulley if you haven't seen any evidence of this having been done on your car before.
Mark your old belt while its still on the pulleys before you take it off with a while paint marker so you can reference the marks on your new belt to ensure you have it timed properly. No need to lock the cams, or remove the crank pulley. See photos below.
2003 XC 70 (sold)
- 5251 Views
Last post by jimmy57
- 23 Replies
- 17132 Views
Last post by jonesg
- 20 Replies
- 17400 Views
Last post by Hurtfeelings
- 4366 Views
Last post by precopster
- 955 Views
Last post by FLXC90
